Home > Forums > OpenFOAM Running, Solving & CFD
Appropriate solver for investigation interaction of wave flow field on a structure?
Like Tree2Likes
  • 1 Post By rafa13
  • 1 Post By mmbeik
Old   February 8, 2015, 02:32
Default Appropriate solver for investigation interaction of wave flow field on a structure?
moh
mmbeik is on a distinguished road
What is the most appropriate solver for investigation on interaction of wave flow field and an structure, considering that I want to add sediment transport model later? any body can help me?
Thanks in advance
mmbeik is offline   Reply With Quote
Old   June 21, 2015, 19:17
Default wave tool box
Rafael Marques
rafa13 is on a distinguished road
HI moh,
you tried waves2foam, but you can use IHFoam. It is a toolbox like waves2foam, it is also a wave generater with a interfoam solver with a porous media model, is also good for the purpose.
greets
RM
rafa13 is offline   Reply With Quote
Old   June 22, 2015, 02:09
moh
Hi Rafael
Thank you for respond. As I know IH Foam solves navierstoks eq. with VRANS. Am I right? But I want use RANS, so I chose waves2foam.
regards
Moh
Old   June 22, 2015, 07:17
Rafael Marques
Hi moh,
thats right IHFoam use the Varans equations for the porous media. But Ihfoam is a interfoam solver when you ant not using porous media. I the porous media zone Ihfoam use the Varans.
Maybe it is interesting for comparing some results or something like this.
Greets
Rafa
mmbeik likes this.
Old   June 23, 2015, 04:26
Rafael Marques
Hi moh,
I tried to figuered out if waves2foam are using or not the Varans ou Vans equations in the porous media and I think they do. I think the porousmedia implementation in opemfoam are based on the varans equation. But i'm not sure, I will continuing to investigate, because I am using IHfoam and Waves2foam to simulate a the effects on wavebreaker
This is maybe a interesting paper.
http://orbit.dtu.dk/ws/files/1028641...ne_Jensen..PDF
the porous media chapter are with the creater of waves2foam.
I didnt read it only overlooked and seems interesting.
greets
RM
Old   June 27, 2015, 01:26
moh
Hi Rafael
Actualy I dont use VRANS and not to model porous media. Just I heared that IHFoam uses VRANS not RANS, so I selected waves2Foam. I hope you success in your research.
regards,
Moh
rafa13 likes this.
Old   July 3, 2015, 07:24
Rafael Marques
HI Moh,
I hope too, and everything good for you work too
greets Rafa
Thread Tools
Trackbacks are On
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
chtMultiRegionFoam - exchange data between flow field and temperature phsieh2005 OpenFOAM Running, Solving & CFD 0 February 7, 2012 10:16
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
Flow field measurement in turbomachinery! Wanlai Lin Main CFD Forum 3 September 3, 1999 12:06
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
