February 9, 2015, 13:55 |
pitching airfoil
Hello
I did one simulation of incompressible flow over a pitching airfoil at Re=12000 using openFoam solver. For example, the velocity contour at one angle of attack is as attachment pic. As you can see, flow has a lot of stagnation point which may not seem correct physically. Is there aerodynamic justification for this streamline? In addition, the solution has been validated in terms of aerodynamic forces. thanks. |
May 27, 2015, 02:32 |
Albin Johny
Rep Power: 11 |
can you tell which dynamicmeshdict you used for pitching
May 27, 2015, 02:58 |
I use this dynamicMeshDict:
dynamicFvMesh dynamicMotionSolverFvMesh; motionSolverLibs ("libfvMotionSolvers.so"); solver displacementLaplacian; diffusivity inverseDistance (airfoil); |
September 20, 2018, 09:54 |
#4 | |
Milad
Rep Power: 8 |
I must do the same project in OF As yours but i am stuck in really bad problem. I generated my mesh in gambit like pic i attached. I dont know why the OF could not recognize the interface boundary. My dynamic mesh dict is same as yours. 1.jpg 2.jpg |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
2D airfoil with heaving and pitching motion | zhereal | Fluent UDF and Scheme Programming | 1 | April 13, 2014 15:18 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
[ICEM] Dynamic mesh for a pitching airfoil | bahram.raeisi | ANSYS Meshing & Geometry | 1 | March 2, 2012 10:41 |
