[swak4Foam] GroovyBC: trying to set a logarithmic BC |
April 6, 2015, 07:36 |
#21 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Loïc,
Attached is "cavityG.tar.gz", which has packaged a modified version of the tutorial "incompressible/icoFoam/cavity" that uses groovyBC to define the flow speed at the "movingWall" boundary. Try running it by using these commands: Code:
tar -xf cavityG.tar.gz cd cavityG blockMesh icoFoam paraFoam If this also doesn't work, then something is incorrectly installed. Best regards, Bruno
April 9, 2015, 08:14 |
#22 |
Loïc Dagnas
Rep Power: 11 |
This problem was tied to the use of shallowWaterFoam. Using time dependant boundary condition was impossible, this will be corrected in the next version taking into account boundary conditions for hU and h instead of U and h (see commit 7077338993a18fdd3bbf8488b172aab15e4d6443 )
April 9, 2015, 09:16 |
#23 |
Did not really solved, but made a artificial pipe, where the profile was created a bit.
Cheers Raitis. |
May 27, 2019, 10:07 |
#24 |
Ainal Hoque Gazi
Rep Power: 7 |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 16:35 |
[swak4Foam] groovyBC set an initial unknown guess constant | ancolli | OpenFOAM Community Contributions | 2 | June 15, 2016 13:46 |
Possible bug with stitchMesh and cyclics in OpenFoam | Jack001 | OpenFOAM Pre-Processing | 0 | May 21, 2016 08:00 |
set BC mass-flow-inlet via UDF and via GUI perform different result | sawa25 | FLUENT | 1 | February 25, 2015 00:51 |
[ICEM] Question about the use of ICEM tcl scripting | lnk | ANSYS Meshing & Geometry | 9 | January 16, 2013 09:24 |
