simpleReactingParcelFoam Secondary Breakup Model
Hey All,
I've got a quick question. I can't figure out if the following breakup models have been implemented in the simpleReactingParcelFoam solver... Code:
$FOAM_SRC/lagrangian/spray/submodels/BreakupModel Code:
atomizationModel none; Has anyone used any of the secondary breakup models in simpleReactingParcelFoam? If so, can someone share with me how to enable them? I'm using the later git versions of 2.3.x (ab7c7a7). Thanks! Brock |
Making these models available in other solvers, requires you to implement your particles as basicSprayCloud (as in sprayFoam). You should however note that basicSprayCloud is based on ReactingCloud, whereas the simpleReactingParcelFoam solver is based on ReactingMultiphaseCloud, hence no multiphase particles with SprayCloud. Cheers, Armin |
