February 26, 2015, 17:53 |
mapFields: for different boundary conditions
SM
Rep Power: 15 |
I want to do RANS of a flow with time varying inlet velocity profile.
For quick convergence I want to first solve with inlet-velocity specified as fixedvalue Later on I want to switch to time varying velocity profile for inlet-velocity with groovyBCFixedValue The OF official documentation says- the fields are deemed ‘consistent’ if the geometry and the boundary types, or conditions, of both source and target fields are identical Since my Boundary conditions are different that means I can not use consistent. How should I handle this change in BC? |
March 28, 2017, 10:13 |
Manu Chakkingal
Rep Power: 10 |
Dear Canopus
Were you able to solve this issue
Regards Manu |
March 28, 2017, 12:13 |
Declan
Rep Power: 9 |
Can you use consistent and then simply edit the boundary condition manually in the mapped U file? This has worked for me.
Open the U file, ctrl+f 'boundaryField', change the type. |
CGNS Boundary conditions using SU2 | denzell | SU2 | 3 | July 9, 2018 05:58 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
