flowRateProfile
I am using coalChemistryFoam.
1,In the patchInjection, there is a keyword "flowRateProfile", what doest it mean? 2, If massTotal is 0.001625, SOI=0, duration=0.5, so massFlowRate=massTotal/duration=0.00325, is it right? Anyone can help me?Thank you. |
I have the same question, what does flowRateProfile mean? |
I'm also working on a Lagrangian dispersion problem.
As far as I understand "FlowRateProfile" specifies the source mass flow rate as a function of time. See for example tutorial ./sprayFoam/aachenBomb/constant/sprayCloudProperites. You could also specify a "sizeDistribution" for the individual particles. Does anyone know of a good documentation source for the Lagrangian Cloud Properties file? I.e. an explanation of what options are and units of parameters? Thanks, Anders |
1.after the simulation, do you know how to count the particles number in a specified area? do you have any hints? 2. do you simulate a steady state or transient state? In tutorial simpleReactingParcelFoam, patch is another inlet which inlet air with a certain velocity. can we just inject particles without airflow? If we can, how should we set the BD. Sorry for my poor English. Hope you can understand. |
By the way, do you know how to count the number of particles after simulation? |
I'd like to do massless Lagrangian particles with stochastic dispersion for a steady state, simpleFoam problem (e.g. a RANS problem).
In principle if I have already computed the velocity field this should be a post processing computation. Do you know of any tutorials on how to do that? Unfortunately I do not know of a good way to count particles. One suggestion is that you could export the position of each particle for the timestep of interest and write a Python or Matlab script to search and count in the 3D subdomain. Regards, Anders |
coal combustion with openfoam
I want to simulate coal combustion in steady State but i couldn't find steady solver for it thus I solves it with coalChemistryFoam which is transient until it reaches to steady state :(. Does anybody have better recommend?:) Ok, I modified coalCloud1Properties to this: Code:
type patchInjection; Is this work right? Is "flowRateProfile constant 1" right? I think it means to uniform profile for particle inject with 'massFlowRate= 0.00458'. Am I right? I set 'parcelsPerSecond = 1e5' approximately. I don't know what must I put exactly. Is it a normal input for it? I excuse because of my poor english writing.:) Best Regards. |
injectionModels has an option "massFlowRate" thus flowRateProfile must be something else. |
Hi...any one figured out what "flowRateProfile" stands for?
I am having a doubt whether it stands for mass flow rate as a function of time but then we do mention massFlowRate in injection model, then why to mention it again? |
FlowRateProfile is a means of varying injected mass flow rate with time by creating a time profile. If you go with the "constant" FlowRateProfile, only one flow rate value will be used throughout the injection period. Alternatively, you can vary the flow rate by making a table with different flow rates at different times during the injection period.
Dear Foamers,
I am trying to simulate a pure pressure driven flow through a nozzle using speayFoam in OpenFoam1812. I would like to obtain the mass flow rate through the nozzle. Here is the relevant info from sprayCloudProperties file: Code:
injectionModels I really appreciate your thoughts on this. Regards, MJ |
I am using patchInjection in denseParticleFoam. My part of the code is: Code:
injectionModels Second question: If I know the mass to feed (massTotal) and time of feed (duration) then I know the mass feed rate. If I know the mass to be fed in one second and Rosin-Rammler particle size distribution then one can calculate the mass based distribution, e.g. m1 mass of 5 to 100 micron particles, m2 mass of 100 to 200 micron particles, and so on. Knowing the mass and particle dia of each size class, one can calculate the number of particles/parcels in each size class. Sum of them is going to be total number of parcels. How this is different from the defined parcelspersecond. I can see the following output in log file of denseParticleFoam: Code:
Solving 3-D cloud cloud |
Hey Rahulksoni,
I have the exact same problem as you and haven't found a way to solve it. However, I noticed that your log file shows the parcel fate for multiple patches. Whenever I run DPMFoam or MPPICFoam I get the Parcel fate for only the system as a whole, how were you able to get the info for individual patches? |
