March 3, 2015, 11:08 |
potentialFoam/cylinder tutorial problems
Nikola
Rep Power: 12 |
Hi to everyone!
I am trying to run the tutorial cylinder, but I am facing some problems. I have looked at other similar threads, but I couldn't find any solution. When I type blockMesh command I receive the error message which I attached as a screenshot, since I cannot copy and paste from the terminal I am using(I am on windows btw). I went to etc/controlDict and changed allowSystemOperations from 0 to 1, but still it doesn't work. I have all the tutorials copied into /home/Nicola/OpenFOAM/nikola-2.3.x/run. However, when I type ./Allrun command, everything seems to work well (except that it doesn't find a line in the code, I attach another screenshot for that too). Did I set something wrong in the installation (running using root account instead of users)? Many thanks in advance! |
March 4, 2015, 03:29 |
Rep Power: 11 |
If it's possible try to use Linux version of OpenFOAM. Ubuntu packages are available on the official site (you don't have to build OpenFOAM by yourself). It can help you to skip a lot of errors when you are deeling with OpenFOAM...
March 5, 2015, 10:17 |
Nikola
Rep Power: 12 |
Ok, I will install and run OpenFOAM on a Linux version. In the meanwhile, any other tips? Thanks.
Problems on mesh adaptation | ervasph | SU2 | 3 | October 12, 2013 11:34 |
in which states and problems we should used correctPhi or ddtPhiCorr ? | mechy | OpenFOAM | 2 | September 14, 2013 08:16 |
Weird problem with engineFoam tutorial | chris1980 | OpenFOAM Running, Solving & CFD | 29 | August 28, 2013 06:53 |
Needed Benchmark Problems for FSI | Mechstud | Main CFD Forum | 4 | July 26, 2011 12:13 |
Problems with channelOodles tutorial | alberto | OpenFOAM Running, Solving & CFD | 0 | June 5, 2007 09:08 |
