March 5, 2015, 18:56 |
problem with chtMultiRegion v.2.1
Rep Power: 11 |
Dear all,
I am completely new to OpenFoam. I am working with a simple case of heat transfer (chtMultiRegionSimpleFoam) between 2 solids on OpenFOAM v.2.1. As far as I understand, I am having trouble applying boundary condition. This is the following message that appears to me: Time = 1 Solving for solid region leftSolid --> FOAM FATAL ERROR: Attempt to cast type calculated to type compressible::turbulentTemperatureCoupledBaffleMix ed From function refCast<To>(From&) in file /home/paula/OpenFOAM/OpenFOAM-2.1.x/src/OpenFOAM/lnInclude/typeInfo.H at line 114. I would be very grateful if anyone could guide and tell me what I am doing wrong. Best Regards Paula |
March 6, 2015, 09:29 |
Aurelien Thinat
Rep Power: 15 |
Hi Paula,
What this error message is saying :
Aurelien |
March 6, 2015, 17:36 |
Rep Power: 11 |
Dear Aurelien
Thanks for your prompt answer and I really appreciate your help and time! Please find attached my case. Have a nice weekend! Schmetterling |
March 7, 2015, 13:15 |
Pascal Balz
Rep Power: 11 |
this should be easy to fix. The 'T'-file in the 0 directory for the leftSolid is set up properly (with turbulentTemperatureCoupledBaffleMixed), whereas the T file of your rightSolid contains the keyword 'calculated' for the coupled wall patch. Change this entry to compressible::turbulentTemperatureCoupledBaffleMix ed (according to your other T-file) and everything should work.
Regards, Pascal |
March 7, 2015, 15:07 |
Rep Power: 11 |
Dear Pascal,
Thanks for your help and time You were right! I´ve changed and it runs! Regards, Schmetterling |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
