icofsifoam in foam-extend 3.0
Old   March 9, 2015, 05:44
Default icofsifoam in foam-extend 3.0
praveen kumar sharma
P Sharma is on a distinguished road
hi openfoam users,
I am using foam-extend 3.0. In which I compiled interFsiFoam (It is combination of interFoam and stressedfoam (both are taken from foam extend only)). when I am running flappingConsole case it gives error
makeFsiResultsLinks for 0
ln: failed to create symbolic link ‘0/solid’: File exists
If anyone already did same work or having same problem in foam-extend 3.0 please guide.
regards,
P Sharma is offline   Reply With Quote
Old   March 9, 2015, 10:05
hxaxtma is on a distinguished road
as the error message says, your symbolic links are already created...
you have to delete them by your own or just write a script which unlink all your files....
create all links again
start your calculation
than create your makeFsiResultsLinks....
it should work
hxaxtma is offline   Reply With Quote
Old   July 28, 2015, 16:38
MD MONIR HOSSAIN
monir99 is on a distinguished road
Dear foamers,
I am trying to to work on interFsiFoam. I got the code from google search.
http://www.tfd.chalmers.se/~hani/kur...edAndFixed.pdf
It was modifeid version of icoFsiFoam on openfoam 1.5 dev. Now there are lot of chages in current openfoam and the code can not find many library. I have tried to modify the code but it still give me some error.
Can someone give me some idea about interFsiFoam code
Any help will be highly appreciated
monir99 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
