Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] Mesh motion problem on fixedValue patch
Like Tree1Likes
  • 1 Post By bigphil
Old   December 31, 2018, 00:25
Default Mesh motion problem on fixedValue patch
Emad Tandis
EmadTandis is on a distinguished road
Hi colleagues,
I was working on large deflection of 2-D beam using my own movingMeshsolver and noticed that meshPhi is not zero at some faces of fixed patches! More delving into the problem, I found that corner points( points located at boundary of fixed and traction patches) moved after solution and this process happens in patchPointInterpolate.C file ( I used volPointInterpolation class to interpolate displacement from cells to points).
I was wondering if someone faced this sort of problem and would be grateful if let me know about solution of keeping corner points fixed?
EmadTandis is offline   Reply With Quote
Old   January 1, 2019, 06:01
Default volPointInterpolation: relative flux (phi) at interface is not zero
Emad Tandis
Hi Bruno,
I was solving a FSI problem, and more precisely, writing a new algorithm in OF. Regarding volPointInterpolation I noticed that the it uses geometrical interpolation implemented in PrimitivePatchInterpolationTemplate.C. file. When I was solving Turek Benchmark problem for FSI (flexible flag behind a cylinder) and also some other FSI problems, I realized that relative flux (phi) at interface is not zero ( which must be zero because motion of the mesh must be equal to the velocity at interface patch). Therefore, since mesh motion at interface point is calculated by interpolation of velocity on facePatch, finally I concluded that (U & A -meshPhi)!=0 and all of that is because of the geometrical interpolation. Am I right?!
[Moderator note: Moved from Point interpolation in OF - given that this is something that affects FSI calculations in specific]
Old   February 19, 2019, 11:27
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Emad,
Did you find this problem with the FSI toolkit? Or with your own implementation?
In the FSi toolkit, interpolation to points is performed using the newLeastSquaresVolPointInterpolation class which should be better at corner points than the volPointInterpolation class.
Philip
Daniel_Khazaei likes this.
bigphil is offline   Reply With Quote
Old   February 19, 2019, 22:37
Emad Tandis
Originally Posted by bigphil View Post
Hi Emad,
Philip
Hi Philip,
Actually I found this problem in both, icoFsiElasticNonLinULSolidFoam and my solver. For example, if one notices phi at interface boundary, non-zero phi (phi is defined as relative flux in icoFsiElasticNonULSolidFoam, as I realized) can be easily seen at this patch, which is non-physical to my eyes.
I wanted to implement newLeastSquaresVolPointInterpolation class, but I faced a couple of errors.
Old   February 20, 2019, 06:02
bigphil's Avatar
Philip Cardiff
Hi Emad,
Can you check if this issue persists in the extendBazaar FSI toolkit and/or the soldis4foam toolkit (PM me and I can give you access to solids4foam)? In particular, I suggest you look at the newMovingWallVelocityFvPatchVectorField boundary condition used for the fluid velocity at the FSI interface.
Philip
Old   February 20, 2019, 12:54
Emad Tandis
Hi Emad,
Philip
I am working with OF-ext4.0 and actually didn't use these tookits. Also, I have seen movingWallVelocityFvPatchVectorField but I don't have newMovingWallVelocityFvPatchVectorField file.
To explain more, I am working on a monolithicFsi solver by unified formulation of solid and fluid, and trying to implement interface condition implicitly. That's why these fvPatchField classes are not that useful for my solver. However, It will be great to gain some information about these tookits and newMovingWallVelocityFvPatchVectorField and have their sources.
Old   February 21, 2019, 12:23
bigphil's Avatar
Philip Cardiff
Hi Emad,
PM me your email and I can share the code.
Philip
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 05:37
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 04:48
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
[GAMBIT] periodic faces not matching Aadhavan ANSYS Meshing & Geometry 6 August 31, 2013 11:25
