interFoam
Old   March 21, 2015, 13:06
Red face interFoam
Darren
Dazzler is on a distinguished road
Hi Guys,
I am hoping someone can provide a little bit of advice regarding interFoam.
I am setting up a number of simulations for a couple of different circumstances but all are water based.
I need to do some investigative work/calibration on flow in pipes/channels so that i can correctly simulate pipe wall friction. I want to find out initially what impacts of using a roughWall Function are in respect of turbulent flow - and what the impacts of using meshes with different laminar layers near the surface are.
The ultimate aim is to simulate flow in a small chamber and river flow. In order to investigate the pipe roughness and compare flow to Colebrook-White values i woudl like to set up a simulation where the flow through some pipes is at constant head.
In other words i need an upper reservoir with alpha at a set level, but with no driving velocity. A constant head tank - i though that this would be relatively simple but im struggling with the boundary conditions.
If i set alpha in my tank to 1 on the walls and use setfields on the rest of the tank i can fill it up with water.
I figure i want to set the velocity on the walls as zerogradient - alpha as 1 - but i dont know what to do with the pressures. Effectively i need the hydrostatic pressure to remain constant and drive the flow - through the walls.
Every combination of boundary conditions seem to result in instability other than setting up the case with no-slip on the walls and zerogradient on the pressure - in which case the phase simply empties out of the tank - the simulation runs but this is not what i am looking for.
Any suggestions ? Do i need the GroovyBC library ?
Dazzler is offline   Reply With Quote
Old   March 23, 2015, 03:54
TobM is on a distinguished road
can you post a drawing of your problem? I'm not entirely sure that I understand your geometry.
TobM is offline   Reply With Quote
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 15:26
interFoam in parallel gooya_kabir OpenFOAM Running, Solving & CFD 0 December 9, 2013 05:09
Problem of InterFoam with LES SpalartAllmarasIDDES keepfit OpenFOAM 3 August 29, 2013 11:21
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
