Difficulties with validation - laminar plate flow
Old   March 25, 2015, 05:12
Default Difficulties with validation - laminar plate flow
subsemitonium is on a distinguished road
I'm trying to validate my calculations with a simple example from VDI Heat Atlas, please find the attached case. I want to make sure that I can produce reasonable results before going any further. Unfortunately I get about 30% error - and all measures to reduce it failed. This is why I'm asking for help now.
Theory: The case is a 1D plate in laminar flow. Theory from VDI Heat Atlas (2013) says:
Nusselt_x = 0,332*sqrt(Re_x)*Pr^(1/3)
with the local Reynolds Number Re_x = w * x /nu with x being the distance over the plate.
In my example, the fluid is water with Prandtl = 7, beta = 2e-4, nu = 1e-6, mu = 1e-3, rho = 1000, cp = 4185
When I run my case, htc is about 30% too high. The solver is buoyantBoussinesqSimpleFoam. Turbulent Prandtl Number is without influence (laminar flow), turbulence models are turned off. I changed many parameters, the only influence I could found is the laminar Prandtl number. To my best knowledge, the laminar Prandtl number in transportProperties is the same "normal" Prandtl number as in thermophysicalProperties - which is a fluid property. Reducing it to a value of 3.5 corrects my results but seems very wrong. On the other hand, I am wondering, why Prandtl number is double-defined.
Any help is very welcome! Thank you.
Edit: Sorry, case file was too large - deleted mesh files. Please execute blockMesh ...
subsemitonium is offline   Reply With Quote
Old   March 26, 2015, 09:39
Nobody interested?
I checked the wallHeatFlux utility by calculating snGrad(T) and using thermal conductivity of water as well as T_wall and T_inlet. I could approximately verify the values by the utility .. which are still about 30% too high compared to the VDI equations. Since I've checked everything else (even tried other solvers for the pressure field) I absolutely don't know ...
Any good ideas?
CFX Treatment of Laminar and Turbulent Flows Jade M CFX 18 September 15, 2022 07:08
compressible laminar flow over flat plate varunjain89 Main CFD Forum 19 April 18, 2019 06:07
laminar flow over a flat plate blasius comparison preetam69 FLUENT 0 September 23, 2013 21:33
i dont understand: grid validation - laminar flow Diegoesteban FLUENT 6 August 19, 2013 17:08
perforated plate, flow direction Benfa CFX 10 August 2, 2013 07:33
