April 2, 2015, 04:37 |
Emulating symmetryPlane boundary conditions
Rep Power: 18 |
I have a case in which I want to make use of the symmetries of the geometry, but in my model I have some antisymmetric fields for which I need a mixed BC with different valueFraction for normal and tangential directions. Now OpenFOAM does not allow to use anything else than a symmetryPlane BC for symmetryPlane patch types.
Is there any way around this? I could remove the check in the code of course, but is this reasonable, or could it cause other problems? As an alternative approach, what are the correct boundary conditions for a symmetry without using symmetryPlane patchType and BC? p: zeroGradient U: slip T: zeroGradient Is this correct? |
April 3, 2015, 08:20 |
Paulo Vatavuk
Rep Power: 17 |
Hi Chriss85,
I think that the conditions that you are using reproduce the symmetry condition for these variables. To be completely sure you may perform two simulations one using the symmetryPlane condition and another using the modified ones, and then compare the results. They should be equal. Best Regards, Paulo |
Symmetryplane, cyclic and wedge boundary conditions | Taltan | OpenFOAM Pre-Processing | 7 | April 18, 2023 11:31 |
Difficulty In Setting Boundary Conditions | Moinul Haque | CFX | 4 | November 25, 2014 17:30 |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 08:39 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
A problem about setting boundary conditions | lyang | Main CFD Forum | 0 | September 19, 1999 18:29 |
