Warning message: Cannot find any patch or group names matching blade1. |
April 2, 2015, 20:11 |
Jishen Zhang
Rep Power: 11 |
I'm turning a simulation of a marine propeller with SRFSimpleFoam solver and each time when I launch the calculation, I receive a warning message like this: Code:
Starting time loop --> FOAM Warning : From function polyBoundaryMesh::patchSet(const wordReList&, const bool, const bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 815 Cannot find any patch or group names matching blade1, --> FOAM Warning : From function polyBoundaryMesh::patchSet(const wordReList&, const bool, const bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 815 Cannot find any patch or group names matching blade2, --> FOAM Warning : From function polyBoundaryMesh::patchSet(const wordReList&, const bool, const bool) const in file meshes/polyMesh/polyBoundaryMesh/polyBoundaryMesh.C at line 815 Cannot find any patch or group names matching blade3, Time = 1 ...... After that the calculation starts to run but at the end of several iterations, the continuity errors explose and the simulation stops. Does anyone have the same experience than I do? Last edited by wyldckat; April 3, 2015 at 12:58. Reason: Added [CODE][/CODE] |
April 3, 2015, 13:33 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: My guess is that the patches are actually named "Blade1", "Blade2" and so on.
If you want a more accurate answer, then please provide more information: http://www.cfd-online.com/Forums/ope...-get-help.html |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
[CGNS] CGNS converters available | mbeaudoin | OpenFOAM Meshing & Mesh Conversion | 137 | December 14, 2018 04:20 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
Are my IRIXbs systune parametersb setting correct | lakeat | OpenFOAM Installation | 1 | May 5, 2008 10:48 |
