April 8, 2015, 01:23 |
Cavitation problem in cavitatingFoam!!!!
Duong Tung
Rep Power: 11 |
Hello all,
I am facing with some problems when I run cavitatingFoam. Actually, my topic is prediction of the cavitation phenomena inside the injector. Therefore, I used cavitatingFoam to simulation this problem. However, there are some different results between 2D and 3D geometry. I think that the results of 3D are absolutely fine, but the 2D case is not good (the cavitation region appears in the undesirable area). I showed some results in some pictures below(the first picture is the result of 2D,the rest is 3D). Could you please help me to find the reason why am I getting cavitating flow in the indicated area? Thank you for all your help! Duong Tung Last edited by gnut1989; April 8, 2015 at 03:22. |
April 8, 2015, 07:29 |
Alexander Bartel
Rep Power: 11 |
Hello Duong Tung,
I am currently working on the same problem, but I am not as far as you are. But I have got one advice. Perhaps you can try the InterPhaseChangeFoam solver too, and decide which of the solver is better. I skipped cavitatingFoam and focused on InterPhaseChangeFoam, because the results seemed to be more feasible and the time for computation was decreased. regards Alex |
April 9, 2015, 01:05 |
#3 | |
Duong Tung
Rep Power: 11 |
Thank you for your quick advice! As I know, the interPhaseChangeFoam is the solver for 2 incompressible, isothermal immiscible fluids with phase - change. However, in my topic, I need to simulate the compressible flows. Is it possible to use interPhaseChangeFoam for my case? Could you please help me to give some explaination about this solver? Best regards, Duong Tung |
April 9, 2015, 07:14 |
Alexander Bartel
Rep Power: 11 |
the first google result for "InterPhaseChangeFoam" is http://www.tfd.chalmers.se/~hani/kur...ChangeFoam.pdf
in this link the tutorial cavitatingBullet is described. IPCF looks legit for cavitation... although the describtion "Solver for 2 incompressible, isothermal immiscible fluids" is a bit confusing. I think "with phase-change (e.g. cavitation)" means that after the phase-change there is also a compressible phase. regards Alex |
April 10, 2015, 01:07 |
#5 | |
Duong Tung
Rep Power: 11 |
Thank you very much for your help! I will try to run with IPCF solver for my case. If you had already any projects which have related with cavitation problem & OpenFOAM, please share them to me to make me understand easily this problem. Best regards, Duong Tung |
April 10, 2015, 01:43 |
#6 | |
Duong Tung
Rep Power: 11 |
Display Modes | |
Problem with cavitatingFoam | clo | OpenFOAM Running, Solving & CFD | 1 | June 7, 2007 12:53 |
convergence problem with FLUENT cavitation model | Belete Kiflie | FLUENT | 3 | February 20, 2006 11:16 |
cavitation problem | dhiman | FLUENT | 0 | February 2, 2006 11:58 |
Cavitation Simulation by CFD | Liu, L. | CFX | 2 | November 29, 2000 14:50 |
Cavitation Simulation by CFD | Liu, L. | Main CFD Forum | 7 | November 1, 2000 22:26 |
