Incomp. LES in pisoFOAM, how to set up Smagorinsky model with van Driest dampin
Like Tree3Likes
Old   February 27, 2012, 11:27
Default Incomp. LES in pisoFOAM, how to set up Smagorinsky model with van Driest dampin
Jan Östh
Jan.Östh is on a distinguished road
Hi all
Im new to OpenFOAM and I'm using v2.1.0 release. My question is regarding the Smagorinsky model implemented in this release. I used the motorBike tutorial to set up an incompressible LES simulation, and to use the Smagorinsky model I specify this in the LESProperties file. So far so good, I get the simulation to run as I anticipated. However, I'm not sure if van Driest damping is incorporated in the standard implementation of the standard Smagorinsky model? From what I have managed to figure out from the file Smagorinsky.H which is located in :
$OpenFOAM_Installation_dir/OpenFOAM-2.1.x/src/turbulenceModels/incompressible/LES/Smagorinsky
it seems to me van Driest damping is not included. My question is, how do I specify that I would like to use the van Driest damping? Right now, for the boundary conditions for nuSgs I have the Spalding wall function specified on my no-slip boundaries.
Cheers
Jan.Östh is offline   Reply With Quote
Old   February 28, 2012, 04:08
Alberto Passalacqua
Set
delta vanDriest;
into LESProperties.
Alberto Passalacqua
Old   February 29, 2012, 08:30
Jan Östh
Originally Posted by alberto View Post
Set
delta vanDriest;
into LESProperties.
Thanks! I also saw your recommendation to use pimpleFoam instead of pisoFoam in another thread. I will try that out...
/Jan
Old   March 2, 2012, 08:41
Jan Östh
Hmm, I get an error when I try to activate the van Driest damping. The only thing I change is to set
delta               vanDriest;
instead of
delta               vanDriest;
in LESProperties. When running the case, the first time step runs:
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.x-82293690fe3e
Exec   : pisoFoam
Date   : Mar 02 2012
Time   : 14:34:06
Host   : "ojan-Precision-WorkStation-T7500"
PID    : 55088
Case   : /home/ojan/OpenFOAM/ojan-2.1.x/LES_2D_cube/LES_2D_cube
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type LESModel
Selecting LES turbulence model Smagorinsky
SmagorinskyCoeffs
    ce              1.05;
    ck              0.0472;
Starting time loop
Time = 0.001
Courant Number mean: 0.080654 max: 3.37697
DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 6.11753e-08, No Iterations 3
DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 1.97382e-07, No Iterations 3
DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 8.11524e-06, No Iterations 2
DICPCG:  Solving for p, Initial residual = 1, Final residual = 0.0485667, No Iterations 321
time step continuity errors : sum local = 1.22778e-05, global = -1.62292e-18, cumulative = -1.62292e-18
DICPCG:  Solving for p, Initial residual = 0.121577, Final residual = 9.51256e-07, No Iterations 404
time step continuity errors : sum local = 1.81875e-09, global = -7.33994e-19, cumulative = -2.35691e-18
But then the solver crashes with the following error message:
#0  Foam::error::printStack(Foam::Ostream&) in "/home/ojan/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/home/ojan/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2   in "/lib/x86_64-linux-gnu/libc.so.6"
#3   in "/lib/x86_64-linux-gnu/libm.so.6"
#4  exp in "/lib/x86_64-linux-gnu/libm.so.6"
#5  Foam::exp(Foam::Field<double>&, Foam::UList<double> const&) in "/home/ojan/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#6  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::exp<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/ojan/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleLESModels.so"
#7  Foam::incompressible::LESModels::vanDriestDelta::calcDelta() in "/home/ojan/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleLESModels.so"
#8  Foam::incompressible::LESModels::Smagorinsky::correct(Foam::tmp<Foam::GeometricField<Foam::Tensor<double>, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/ojan/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleLESModels.so"
#9  Foam::incompressible::LESModel::correct() in "/home/ojan/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libincompressibleLESModels.so"
 in "/home/ojan/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/pisoFoam"
#11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#12
Floating point exception
Anybody knows what might be causing this? I'm using Ubuntu 11.04...
Old   March 2, 2012, 08:59
calim_cfd's Avatar
mauricio
calim_cfd is on a distinguished road
hi!
i'm not that familiar with les, specially in of, yet, but have you check out the tutorials:
/tutorials/compressible/rhoPimpleFoam/les/pitzDaily/constant/LESProperties
/tutorials/combustion/fireFoam/les/smallPoolFire3D/constant/LESProperties
/tutorials/combustion/fireFoam/les/oppositeBurningPanels/constant/LESProperties
/tutorials/combustion/fireFoam/les/smallPoolFire2D/constant/LESProperties
/tutorials/combustion/XiFoam/les/pitzDaily3D/constant/LESProperties
/tutorials/combustion/XiFoam/les/pitzDaily/constant/LESProperties
/tutorials/incompressible/channelFoam/channel395/constant/LESProperties
also you're running a transient solver.. try checking your settings with a steady-state one.. then switch over. i normally find it harder to get a transient solver to work at first
hope it helps!
regards
calim_cfd is offline   Reply With Quote
Old   March 2, 2012, 09:09
Jan Östh
Thanks for the reply, I will go through the tutorials. However, the above error was created by activating the van Driest damping. Before that, the simulation was running as it should...
Old   March 2, 2012, 09:17
calim_cfd's Avatar
mauricio
then i guess the problem is the annoying one.. solver/schemes/timestep settings..
can't help you much there.. too many parameters at this point
sry
Old   March 2, 2012, 11:54
Alberto Passalacqua
It is actually a bug, since it happens even in tutorials, if you use vanDriest. I reported it: http://www.openfoam.org/mantisbt/view.php?id=445
solefire likes this.
Alberto Passalacqua
Old   March 4, 2012, 02:59
Alberto Passalacqua
Short update: I investigated more using the pisoFoam/pitzDaily tutorial. The problem originates from the exp at line 93:
(kappa_/Cdelta_)*((scalar(1) + SMALL) - exp(-y/ystar/Aplus_))*y
I inspected the values of the argument at the first iteration and I obtained:
min(y) -1e+15
max(y) 0.000566292
min(ystar) 8.46024e-06
max(ystar) 1
It seems the minimum wall distance is computed incorrectly and leads to an overflow of the exponential function.
solefire and beatlejuice like this.
Alberto Passalacqua
Last edited by alberto; March 4, 2012 at 04:15. Reason: The content was not correct.
Old   March 4, 2012, 08:59
calim_cfd's Avatar
mauricio
min(y) -1e+15
max(y) 0.000566292
max(ystar) 1
interesting... i wish i had more time to check it out since i should be working with les soon enough.
one last thought..
you said the error appears even in the tutorials right? but does the error occurs with the "stock settings"?
cuz.. i mean.. say you have a tutorial and change the turbulence settings as you need..
have you checked the possibility of a mesh error?? check that for your mesh and the tutorial one... YplusLES should help you with the checking...
if mesh is not the issue, my hands are now tight..
sry and good luck!
Old   March 4, 2012, 22:05
Alberto Passalacqua
Some work with git bisect showed that the problem is related to commit c06792759a720eb9d1494b4b4b0c3a86d21c20b0
http://www.openfoam.org/mantisbt/view.php?id=448
Alberto Passalacqua
Old   March 5, 2012, 07:30
Jan Östh
Ok great work, thanks alberto. I tried the OpenFoam v2.0 release and that was ok.
Old   March 5, 2012, 08:15
Alberto Passalacqua
OpenCFD fixed the bug in git for 2.1.x (See bug-report).
Alberto Passalacqua
Old   March 5, 2012, 10:46
Jan Östh
Great. I updated the release and now it works using van Driest (at least it doesn't crash).
/Jan
Old   March 17, 2014, 21:53
Peter
palmerlee is on a distinguished road
Hi, alberto!
I wonder if there is a way to fix the bug in OpenFoam 2.0.1. For some reason, I kind of have to use this version of OpenFoam. Could you please give me some hits? My OS system is Ubuntu 11.04.
Best regards
Peter
palmerlee is offline   Reply With Quote
Old   April 30, 2014, 23:14
Default van Driest damping fuction
  #16
ehk
ehsankf is on a distinguished road
Hi all,
Any body can point me to a paper for the van Driest damping function implemented in the Openfoam.
Thanks.
ehsankf is offline   Reply With Quote
Old   May 1, 2014, 01:51
Andrew Somorjai
massive_turbulence is on a distinguished road
Originally Posted by ehsankf View Post
Hi all,
Thanks.
There are references here
http://www.cfd-online.com/Wiki/Near-...for_LES_models
http://www.fluidosol.se/thesismod/paper5.pdf
Hope it works for you.
massive_turbulence is offline   Reply With Quote
Old   May 1, 2014, 02:09
ehk
The van Driest damping function in OpenFoam is applied in different way. In OpenFoam, the damping is derived by changing the filter width, depending on the distance from the wall. You may want to look at equation 2.7 in this document
http://www.tfd.chalmers.se/~hani/kur...jectReport.pdf
Any reference for that?
Old   September 17, 2014, 06:18
Hans Barósz
HanSolo123 is on a distinguished road
Hi ehk,
in my opinion the statement for Delta in the report you posted is wrong.
When I check eq. 2.7 with https://github.com/OpenFOAM/OpenFOAM...nDriestDelta.C
I can see a difference.
It should be:
Delta = min[Delta , kappa/C_d * (1 - exp(yPlus/APlus))*y]
and not
Delta = min[Delta , kappa/C_d] * (1 - exp(yPlus/APlus))*y
So the damping function only effects the right term of the min expression. Can someone confirm this?
HanSolo123 is offline   Reply With Quote
Old   August 4, 2016, 11:22
Esther Jin is on a distinguished road
Hello, I am doing LES turbulence simulation using OpenFOAM3.0.1, and have some questions about the turbulenceProperties in the constant folder of pitzDaily in tutorials, I don't understand what LESdelta means, is it related to filter width?
simulationType  LES;
LES
    LESModel        dynamicKEqn;
    turbulence      on;
    printCoeffs     on;
    delta           cubeRootVol;
    dynamicKEqnCoeffs
        filter simple;
    cubeRootVolCoeffs
        deltaCoeff      1;
    PrandtlCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        smoothCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            maxDeltaRatio   1.1;
        Cdelta          0.158;
    vanDriestCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        smoothCoeffs
            delta           cubeRootVol;
            cubeRootVolCoeffs
                deltaCoeff      1;
            maxDeltaRatio   1.1;
        Aplus           26;
        Cdelta          0.158;
    smoothCoeffs
        delta           cubeRootVol;
        cubeRootVolCoeffs
            deltaCoeff      1;
        maxDeltaRatio   1.1;
If I choose VanDriest as Delta, in log file it shows the LES delta type selected twice,
PHP Code:
PIMPLEOperating solver in PISO mode
Reading field p
Reading field U
Reading
Selecting LES delta type vanDriest
Selecting LES delta type cubeRootVol
SmagorinskyCoeffs
Ck              0.094;
Ce              1.048;
I also want to use Van Driest damping function, but I am so confused with these LES deltas and coefficients. Could anyone please explain me about these parameters if you have experience with LES turbulent flow simulation?
Thank you in advance!
Best regards,
Esther
Esther Jin is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
LES Compressible Smagorinsky Model iyer_arvind OpenFOAM Running, Solving & CFD 26 September 9, 2014 07:22
LES and combustion model Margherita Cadorin CFX 0 October 29, 2008 05:24
Smagorinsky closure model for LES Jimmy FLUENT 0 December 18, 2002 04:33
2-equation model of LES and source code M.R.Hadian Main CFD Forum 0 February 3, 2002 05:00
