April 13, 2015, 04:36 |
Source term using PisoFoam
Sylvain
Rep Power: 11 |
I want to use pisoFoam with periodic boundary conditions. I usually use simpleFoam or pimpleFoam using the momentumSource into the fvOptions file, but it doesn't seem to be available with pisoFoam. Can anyone confirm that? Do i need to implement the momentum source directly into the solver ? Thanks Sylvain |
April 13, 2015, 04:55 |
No, there is no fvOptions functionality available in pisoFoam. Though, if you set nOuterCorrectors to 1, you can turn pimpleFoam into pisoFoam. Below is an excerpt from pimpleControl.C: Code:
if (nCorrPIMPLE_ > 1) { ... } else { Info<< nl << algorithmName_ << ": Operating solver in PISO mode" << nl << endl; } |
April 13, 2015, 05:13 |
Sylvain
Rep Power: 11 |
Thanks Alexey
Display Modes | |
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 15:22 |
Source Term to pisoFoam | desanga | OpenFOAM Programming & Development | 3 | October 11, 2014 10:26 |
[swak4Foam] Error bulding swak4Foam | sfigato | OpenFOAM Community Contributions | 18 | August 22, 2013 13:41 |
Gravity source term in PisoFoam | DanM | OpenFOAM Running, Solving & CFD | 4 | May 24, 2013 12:30 |
UDFs for Scalar Eqn - Fluid/Solid HT | Greg Perkins | FLUENT | 0 | October 11, 2000 04:43 |
