April 13, 2015, 09:43 |
Condensation & EulerianFoam
Akr
Rep Power: 10 |
Hello Dear Foamers,
My work is based on Condensation due to Constant wall temperature over a vertical geometry. For the simplicity i have used Steam as the fluid at inlet at 373K, and the left and right wall temperature are fixed to a temperature below Tsat. I have set the Pressure in the internal field of domain to be at atmospheric and so do the pressure outlet. The initial conditions for my test case is provided as below: 0/U1 internalField uniform (0 1 0) inlet - fixedValue (0 1 0); outlet-zeroGradient; walls-fixedValue(0 0 0); (no slip) 0/p internalField uniform 0 inlet - zeroGradient; outlet-fixedValue; uniform 0; walls- zeroGradient; 0/alpha1 internalField uniform 1 (as inlet i have steam which i assume to be 1) inlet - fixedValue, uniform 1; outlet-zeroGradient; walls- zeroGradient; The problem i face is, there is a REVERSE FLOW within the domain, with these boundary conditions i get a reverse flow inside the domain (at the inlet as well as at the outlet) If i ignore gravity (9.81 m/s2) then i get the test case to run (widout reverse flow) bt it doesnt show up any alpha change. with g value set as -9.81m/s2 the reverse flow happens and the iterations immediately shows sigFpe errors. I would be extremely thankful if some one suggest me a solution |
September 21, 2015, 01:47 |
Akr
Rep Power: 10 |
The problem was solved. It was due to my pressure boundary condition which i stated wrongly according to my context and the sign of my gravitational acceleration term was wrongly inputed
Display Modes | |
How accurate can CFX model condensation? | JuPa | CFX | 7 | January 20, 2019 18:17 |
Problem setting up Condensation | cwl | STAR-CCM+ | 2 | September 1, 2017 07:35 |
1D test case about condensation | kawamura | OpenFOAM | 5 | September 9, 2013 06:21 |
Condensation as an additional variable | Clark Griswold | CFX | 2 | April 21, 2012 08:20 |
combustion radiation and condensation in cfx | siden | CFX | 1 | February 3, 2011 18:39 |
