got some error with reactingFoam 2D
Old   April 16, 2015, 07:18
Unhappy got some error with reactingFoam 2D
J. L.
kyran is on a distinguished road
I made a model based on counterFlowFlame2D using reactingFoam. But I got some error which stopped computation.
Can some one tell me what the problem is and how can I solve the problem? I will appreciate any help. Thank you very much.
The error messages are as below
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
#0 Foam::error:: printStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 Uninterpreted:
#3 Foam::EulerImplicit<Foam::chemistryModel<Foam:: psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Fo am::janafThermo<Foam:: perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::solve(Foam::Field<double>&, double&, double&, double&, double&) const at ??:?
#4 double Foam::chemistryModel<Foam:: psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Fo am::janafThermo<Foam:: perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::solve<Foam::UniformField<double> >(Foam::UniformField<double> const&) at ??:?
#5 Foam::chemistryModel<Foam:: psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Fo am::janafThermo<Foam:: perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::solve(double) at ??:?
#6 Foam::combustionModels::laminar<Foam::combustionMo dels:: psiChemistryCombustion>::correct() at ??:?
at ??:?
#8 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
at ??:?
Floating point exception (core dumped)
kyran is offline   Reply With Quote
Old   October 1, 2015, 22:35
Rishikesh Ranade
rishikeshranade is on a distinguished road
Did you find an answer?
rishikeshranade is offline   Reply With Quote
How to switch off combustion and reaction in reactingFoam shenzhou1987 OpenFOAM Running, Solving & CFD 16 October 26, 2017 15:31
calculate flame speed using reactingFoam IColin OpenFOAM Running, Solving & CFD 0 February 4, 2014 15:14
reactingFoam , FOAM Warning : Increase time precision and then crash camille131 OpenFOAM Running, Solving & CFD 7 March 26, 2013 13:50
reactingFoam wedge handling wrong U dhondupant OpenFOAM Bugs 1 December 9, 2010 07:34
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 12:57
