Numerical spurious modes at processors interface in parallel run |
April 21, 2015, 04:35 |
Rep Power: 12 |
Hi all,
I simulate s cyclic 2D domain using a solver I wrote (based on buoyantBoussinesqPimpleFoam) - that solver was tested on analytical results. The parallel simulation is divided on 32 processors (8 horizontal, 4 vertical). As you can see (first picture), I get some spurious modes between the processors interfaces. However, If I take this timestep as initial conditions for a single processor, the spurious modes disappear (very quickly), as can be seen in the second picture. Any idea? Did somebody see this before? Is it related to the discretization schemes? the linear solver? |
April 22, 2015, 03:35 |
Hrvoje Jasak
Rep Power: 33 |
Did you reconstruct before post-processing or are you using Paraview native reader. Paraview is not aware of parallel decomposition, so it does not do the correct interpolation to points at processor boundaries.
Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
April 22, 2015, 04:06 |
Rep Power: 12 |
Thank you for your reply. The result's you see are after the reconstruction. However, I tested the same case with the OF solver it is OK. So presently I assume that it has to do with my solver. I will update further developments |
Display Modes | |
Error running simpleFoam in parallel | Yuby | OpenFOAM Running, Solving & CFD | 14 | October 7, 2021 04:38 |
Can not run OpenFOAM in parallel in clusters, help! | ripperjack | OpenFOAM Running, Solving & CFD | 5 | May 6, 2014 15:25 |
The results difference between parallel and serial run. | Hkp | OpenFOAM Running, Solving & CFD | 2 | April 17, 2014 02:26 |
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel | JR22 | OpenFOAM Running, Solving & CFD | 2 | April 19, 2013 16:49 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
