Conditions in which yPlus does not matter
Hi FOAMers!
I am running a turbulence case of an incompressible flow around a rotating disc. The yPlusRAS utility gives me this values: Code:
Patch 5 named cuerpo y+ : min: 0.0062716 max: 42.1937 average: 3.33432 My question is: Does a combination of turbulence model+boundary conditions at the walls/wall function exist in which the yPlus value doesn't matter? As I have read, omegaWallfunction can change from Low-Re to High-Re, but in this thread is not completely clear: http://www.cfd-online.com/Forums/ope...omega-sst.html The paper of Menter agrees. So, I am a little bit worried, because I don't know what to do. In this paper http://www.tfd.chalmers.se/~hani/kur...DES-Report.pdf, the only wall function they use is the omegaWallfunction, and they don't talk about yPlus, so I don't know if it does matter.... Can you help me? I would like to finish my thesis, but I am confused.. :confused: Thank you very much in advance :) !!! |
My current boundary conditions are:
kinetic energy: Code:
GNU nano 2.2.6 Archivo: 0.org/k Code:
GNU nano 2.2.6 Archivo: nut frontBackUpperPatches: Code:
GNU nano 2.2.6 Archivo: frontBackUpperPatches initialconditions: Code:
GNU nano 2.2.6 Archivo: initialConditions |
There are no RANS turbulence models which depend on y+ on one way other another. However, you could try to use the approach described in post 3 of the thread that you mentioned http://www.cfd-online.com/Forums/ope...tml#post306339 with the nutUSpaldingWallFunction for nut. |
