how to add turbulent dispersion term in twoPhaseEulerFoam?
Old   April 21, 2015, 09:18
Default how to add turbulent dispersion term in twoPhaseEulerFoam?
Yucheng Fu
Yucheng Fu is on a distinguished road
In the twoPhaseEulerFoam/constant/phaseProperties file, there is a term called turbulent dispersion term. But it's left blank in tutorials. Which kind of format should I follow if I want to add that term in the problem?
Yucheng Fu is offline   Reply With Quote
Old   April 21, 2015, 17:06
hester is on a distinguished road
if you want to use the turbulent dispersion force, you have to define the coefficient Ctd. There are different models defined under twoPhaseEulerFoam/interfacialModels/turbulentDispersionModels/.
A constant coefficient is defined by
        type            constantCoefficient;
        Ctd             0.1;
There is also a model after Gosman, which I'm not familiar with. It needs a definition of sigma.
If you are unsure what variables need to be defined or how a term is implemented have a look at the source code. In the header-file is often also a reference paper for further reading given.
Regards,
hester
hester is offline   Reply With Quote
Old   April 28, 2015, 00:04
Yucheng Fu
Hi,hester
Thank you for your help, I think my question is solved
according to your responding!
        Ctd             0.1;
Regards,
hester
Adding radiation source term in twoPhaseEulerFoam solver tos OpenFOAM Programming & Development 0 April 8, 2014 10:57
Add source term in alphaEqn.H of interFoam tayo OpenFOAM 1 October 23, 2013 03:40
twoPhaseEulerFoam & Source term Aurelien Thinat OpenFOAM Programming & Development 0 September 10, 2013 06:26
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Add source term in species equation zhou1 FLUENT 1 October 21, 2003 06:28
