chtmultiregionFoam problem with fluid
Old   April 28, 2015, 16:19
Default chtmultiregionFoam problem with fluid
Gerardo Zegers
Gzegers is on a distinguished road
I want to solve the heat transfer between water and a cylinder in the center of the domain. The water is moving form left to right and the inlet is with higher temperature ( I attach mi files).
When I change the fluid from air to water ( I take the properties of water from heatTransfer/chtMultiRegionFoam/multiRegionHeater/constant/bottomWater ) I get an error with the thermal properties.
[2]     From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const
[2]     in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76.
[2] [4]
Can you help me to fix this problem?
Thanks
Gerardo
Gzegers is offline   Reply With Quote
chtmultiregionfoam, heat tranfer laminar, snappyhexmesh 3d
chtMultiRegionFoam connection between solid and fluid region of heat exchanger ahab OpenFOAM 1 December 18, 2019 00:37
Two Fluid bouyant problem and mesh DariusBic FLOW-3D 0 May 12, 2011 06:49
Problem setting with chtmultiregionFoam Antonin OpenFOAM Running, Solving & CFD 3 July 20, 2009 06:52
VOF - fluid property problem weechristo FLUENT 1 April 11, 2009 15:08
Problem in fluid zone!!! STK FLUENT 2 September 1, 2004 15:27
