How are the integration constants for the JANAFthermo class derived?
Old   March 9, 2011, 03:27
Default How are the integration constants for the JANAFthermo class derived?
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Dear all,
I am looking for a bit more information on the derivation of the integration constants for the JANAFthermo. As explained in the user guide:http://www.openfoam.com/docs/user/th...hp#x37-2040012 we have 2 times 7 constants that are required for the thermodynamic properties. One set for a low temperature regime, and one set for the high temperature regime. For these sets, the first 5 constants create the polynomial function to calculate Cp as a function of T. Than there are two integration constants, which are mentioned in the User Guide. One is used to determine the enthalpy and one for the entropy. However it is not quite clear to me how these constants are derived. What is the integration that is performed which leads to these integration constant? So how to determine these constants from thermodynamic data?
I hope someone can explain this.
Kind regards,
Tom
tomf is offline   Reply With Quote
Old   May 14, 2015, 05:51
Mieszko Młody
ziemowitzima is on a distinguished road
I was long time ago, but I have similar question.
Did you manage to find the aswer ?
I general we have Cp(T), then:
1. H = integral(CP) dT + constant1
2. S = integral(CP/T)dT + constant2
but what is the value of the constant1 and constant2 ?
best
ziemowitzima is offline   Reply With Quote
Old   May 15, 2015, 07:47
Tom Fahner
Unfortunately I do not remember exactly. I believe I ultimately found the data I needed somewhere. For the enthalpy I think it is based on the formation enthalpy, but I do not think I needed the entropy part.
So basically I do not think I can help you any further.
Regards,
Tom
How to access solver fields from fvPatchField%2360Type derived class that defines BC kar OpenFOAM Running, Solving & CFD 0 February 29, 2008 12:41
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
