June 25, 2019, 11:54 |
Initial Conditions to have pipe filled
Suresh raja
Rep Power: 11 |
I am using interFoam to predict the flow rate and time to drain out oil from a pipeline due to a rupture (may be modeled as an orifice). This is an incompressible flow but needs to be solved by first starting with the pipeline completely filled. Once a rupture occurs in the pipeline, the pump will be shut off. I am looking to predict the flow rate and the time to drain the liquids in the pipeline. The pipeline will also have variations in elevations that follow the terrain.
How would I set the initial conditions to have the pipeline filled with oil/liquid? There should be no incoming flow at t=0. At the initial time, the pipeline is filled completely (pressure = 1480 psig) and then see how long it will take to drain out due to the pipeline inclination (due to terrain)? I am not sure how to setup the initial condition "0" to satisfy this with the interFoam solver. Thanks for your help! |
interfoam, openfoam, pipelines |
Segmentation fault when using reactingFOAM for Fluids | Tommy Floessner | OpenFOAM Running, Solving & CFD | 4 | April 22, 2018 12:30 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
HeatSource BC to the whole region in chtMultiRegionHeater | xsa | OpenFOAM Running, Solving & CFD | 3 | November 7, 2016 05:07 |
SLTS+rhoPisoFoam: what is rDeltaT??? | nileshjrane | OpenFOAM Running, Solving & CFD | 4 | February 25, 2013 04:13 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
