simpleFoam convergence issue
Like Tree3Likes
  • 2 Post By Kina
  • 1 Post By Kina
Old   March 1, 2016, 00:15
Default simpleFoam convergence issue
Harnoor Singh
Harnoor is on a distinguished road
I am new to OpenFoam. I am trying to simulate flow over a 3-d wing (sd 6060 airfoil) at Re=80000. I have created my mesh in icem-cfd and imported it in Openfoam. I am using k omega SST model and I have specified all boundary conditions to the best of my knowledge. I am using simpleFoam as the solver. The solution does not converge and I am getting completely wrong results. I am pasting my case files below. Can someone please take a look and tell me where the problem is? Any help would be greatly appreciated.
k
internalField uniform 2.77e-8;
boundaryField
near_side
type symmetryPlane;
far_side
type fixedValue;
value uniform 2.77e-8;
outlet
type fixedValue;
inlet
type fixedValue;
wing_surface
type kqRWallFunction;
value uniform 1e-11;
wing_tip
omega
internalField uniform 3.28;
boundaryField
near_side
type symmetryPlane;
far_side
type fixedValue;
value uniform 3.28;
outlet
type fixedValue;
value uniform 3.28;
inlet
type fixedValue;
value uniform 3.28;
wing_surface
type omegaWallFunction;
value uniform 2.688e6;
wing_tip
value uniform 1.421e3;
p
internalField uniform 86974;
boundaryField
inlet
type fixedValue;
value uniform 86974;
outlet
type fixedValue;
wing_surface
type zeroGradient;
near_side
type symmetryPlane;
far_side
type fixedValue;
wing_tip
type zeroGradient;
U
internalField uniform (8.533 0 0);
boundaryField
inlet
type fixedValue;
value uniform (8.533 0 0);
outlet
type fixedValue;
wing_surface
type fixedValue;
value uniform (0 0 0);
near_side
type symmetryPlane;
far_side
type fixedValue;
wing_tip
type fixedValue;
nut
internalField uniform 8.446e-9;
boundaryField
near_side
type symmetryPlane;
far_side
type calculated;
value uniform 8.446e-9;
outlet
type calculated;
inlet
type calculated;
wing_surface
type nutkWallFunction;
value uniform 7.73e-12;
wing_tip
fvSchemes
ddtSchemes
default steadyState;
gradSchemes
default Gauss linear;
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwindV grad(U);
div(phi,k) bounded Gauss upwind;
div(phi,omega) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
fvSolution
solvers
p
solver GAMG;
tolerance 1e-7;
relTol 0.01;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
U
solver smoothSolver;
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
k
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
omega
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 0;
potentialFlow
nNonOrthogonalCorrectors 10;
relaxationFactors
fields
p 0.2;
equations
U 0.5;
k 0.5;
omega 0.5;
cache
grad(U);
controlDict
deltaT 0.01;
writeControl timeStep;
writeInterval 50;
Pls tell me where the problem is?
Harnoor is offline   Reply With Quote
Old   March 1, 2016, 04:26
anonymous
ssss is on a distinguished road
Increase NonOrthogonalCorrectors to 1
Change div(phi, U) to upwind
Change default gradient scheme to:
default cellMDLimited Gauss linear 0.5;
Do you think that your mesh has enough quality? Do you have tetrahedral elements on the boundary patches? Which is your expected y+?
ssss is offline   Reply With Quote
Old   March 5, 2016, 08:17
Default 3d Wing simulation is simpleFoam
Harnoor Singh
I have made the changes in non orthogonal correctors, div(U,phi) scheme and default grad scheme. Now, the results are less crazier than last time. But, the solution is still incorrect. The value of Ux sarts becoming increasingly negative after abut 15 seconds. The order of magnitude of U is becoming very large at certain locations near the outlet. Also, while viewing in paraview, I noticed that the errors originate at the outlet boundary and propagate towards the inlet. So, my intuition is that there is a problem in the boundary conditions. Can someone please check the type and value of my BC's.
To answer your previous question, my mesh quality is fine. My expected y+ value is 1.9. I dont know how to check if my patches are surrounded by tetragonal cells. checkMesh yielded that mesh is fine.
I have attached an image of my geometry, which can be viewed to get an idea of the location of boundary patches.
Old   March 5, 2016, 11:47
Alex
Kina is on a distinguished road
Okay,
just some thoughts you might consider:
you are specifying very many conditions for the initial variables.
Usually, I define the BCs as follows:
U:
Inlet: fixedValue
Outlet: zeroGradient
side walls: slip
airfoil fixedValue 0 0 0
p:
Inlet: zeroGradient
outlet: fixedValue $internalField (value of internal field)
side: zeroGradient
airfoil: zeroGradient
k:
Inlet: either fixedValue or turbulentKineticEnergyinlet
outlet: zeroGradient
side: zeroGradient
airfoil: zeroGradient or kqRWallFunction
omega:
inlet: either fixedValue or turbulentMixingLengthFrequencyInlet
side: zeroGradient
airfoil: omegaWallFunction
Also, you might want to set the gradSchemes to cellMDLimited Gauss Linear 0.5
That's all I would change for now just to see if it makes something better.
You could post 3 steps of your log file or attach the whole file if the problem persists. Sometimes, the behavior of the residuals tell the whole story.
Cheers
Alex
Kina is offline   Reply With Quote
Old   March 6, 2016, 08:41
Harnoor Singh
Thanks a ton Alex. It worked like a charm. Just changed the BC's as you suggested.
There was still one slight problem. The pressure wasnt converging completely. After 2 hours, the initial and final residuals were practically constant over time. I stopped the simulation after 3 hours. The pressure results look more or less correct. But, is there something that could be done in this regard? The velocities and other variables have converged without any problem.
Old   March 6, 2016, 09:26
Alex
Could you post your current fvSchemes and fvSolution file? Please post it as <Code> for better overview
Old   March 7, 2016, 11:43
Default fvsolution
Harnoor Singh
fvsolution
solvers
p
solver GAMG;
tolerance 1e-7;
relTol 0.01;
nPreSweeps 0;
nPostSweeps 2;
mergeLevels 1;
U
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
k
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
omega
tolerance 1e-8;
relTol 0.1;
nSweeps 1;
SIMPLE
nNonOrthogonalCorrectors 1;
potentialFlow
relaxationFactors
fields
p 0.2;
equations
U 0.5;
k 0.5;
omega 0.5;
cache
grad(U);
Old   March 7, 2016, 11:44
Default fvschemes
Harnoor Singh
fvschemes
ddtSchemes
gradSchemes
divSchemes
default none;
div(phi,U) bounded Gauss upwind;
laplacianSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
Old   March 7, 2016, 12:43
Alex
Okay, again some suggestions. For p, change the solver settings (fvSolution) to tolerance 1e-10, nCellsInCoarsestLvl to 120 (speeds up the computation time).
Then, again to the p-GAMG-solver, add: maxIter 500; also a good speed boost, and the 500 additional iterations barely help.
Also, in the SIMPLE settings, add the line nCorrectors 1 and change the nOrthogonalCorrectors to 3.
Then, in fvSchemes, you can change the grad(U) to Gauss Linear and the div(phi,U) term to bounded Gauss linearUpwind grad(U).
If none of those suggestions helps you, you can also try setting the laplacian scheme in the fvSchemes to Gauss linear uncorrected or Gauss linear limited 0.5. This should do the job but I wouldn't recommend it until it's necessary.
Cheers
Alex
96faizizzuddin and zyzycomcn like this.
Old   March 11, 2016, 09:32
Harnoor Singh
I tried the changes that you suggested but it didn't make much of a difference.
However, I plotted the coefficient of drag and lift vs time for my simulation. I found out that they are converging beautifully (Plots attached below). All variables except p are completely converging. p gets struck at 1 iteration/time step after 20 seconds and then starts oscillating. Now, I have some questions -
1. Since the force coefficients are converging, is it fine to assume that simulation results are correct. Can I neglect the minor issue with p?
2. The values of Coefficient of drag and lift I am getting are 0.025 and 0.123 respectively. The experimental values are 0.018 and 0.121. The coefficient of lift is spot on. But there is a some error in drag coefficient. Can it be attributed to the fact that the experimental free stream turbulence level was 0.5% whereas in the simulation it was 0.001%? How big a deal is this?
3. I cant find out a way to set the free stream turbulence intensity to 0.5% in k-omega sst model. This is because of the restrictions imposed on the value of nut infinity in k-omega sst. It must lie between 10^(-5) to 10^(-2) times nu infinity. nu infinity for our case is 1.6^(-5). This restriction puts a bound on the maximum value of TKE and hence on free stream turbulence. Is there any way to solve this problem?
4. After the simulation, I tried to generate the log file by the commands -
foamJob simpleFoam
foamLog log
But, the generated log files only contain the last few timestep data (Around 10 delta t). I have no idea why this is happening. This is the reason that I haven't been able to plot the residuals using gnuplot. Is there anything wrong with my commands?
5. Could the error in the value of drag coefficient be attributed to the fact that I am using a steady state solver? My problem appears to have no transient phenomenon whatsoever.
6. I am trying to simulate flow over a wing on which experiments have already been performed. The paper that I am using only specifies the chord length. It does not specify the wing span. Can I take any arbitrary wing span without effecting the force coefficients? I mean would the end effects (due o wing tips) really have any significant influence on the force coefficients? What is the minimum span that I should keep (In terms of chord length) to avoid errors due to end effects?
Thanks in advance.
Old   March 12, 2016, 12:08
Alex
foamJob simpleFoam
foamLog log
Thanks in advance.
1. Yes and no Converging coefficients mean that your solution is stable and the result is the best outcome your setup can produce. Around what value (1e-4, 1e-5) are your pressure residuals oscillating? Is it possible that your residual plot software interprets the 3 nOrthogonalCorrectors as oscillating since the pressure is solved three times in one iteration meaning the GAMG produces three output lines of residuals per iteration?
2. I think the freestream turbulence is a minor issue regarding your simulation results. The problem of OF's kOmegaSST is that it is just in High Re formulation. Can you switch the k-wall BC to kLowReWallFunction? Also, if you are including nut in your /0 folder, you can set the wall BC to nutLowReWallFunction. High-Re kOmegaSST tends to overpredict drag even in Low-Re meshes. Another possibility would be to use the kkLOmega model as it simulates transitional flow. I found it to be performing well when dealing with a transitional boundary layer (I am not sure if that's the case in your simulation)
3. Read about the turbulentIntensityKineticEnergyInlet BC for 0/k. Maybe this is a way for you to define your turbulence values. Or did I misunderstand the question?
4. I am generating my log file by putting an empty text document named "log" in the case directory and starting the simulation with
simpleFoam >log
This way, the whole simulation is written into this text document. I am not sure if this works for you.
5. I am pretty sure that this is not the case.
6. That is actually a tough question since a too short wing produces too much induced drag compared to the regular drag of the middle section of the wing. If you have information about what kind of airplane this wing could be used for you could make a pretty accurate guess by looking at the technical data of the airplane. If there is nothing mentioned I'd look at typical airplane wingspans. Since the lift is also affected by the wing geometry (e.g. washout), you might have already chosen just the right wingspan.
What is your yPlus value after the simulation?
yPlus -latestTime
For the kkLOmega you should keep y+<1 and also for the LowReWallFunctions in SST this is a good thing. I found that a too coarse mesh generally overpredicts lift.
Cheers
Alex
belier1988 likes this.
Old   March 12, 2016, 12:12
Alex
Oh and for your drag you can also play around with the convection terms:
div(phi,U)
div(p,U)
I found that the drag coefficient in my simulations with SST changes when changing from upwind to linearUpwind, linear or limitedLinear 1. This is also logical since a 2nd order scheme is more resistant to numerical errors.
Old   March 14, 2016, 00:58
Parth Thakkar
mech_engg_swag is on a distinguished road
Sir, I am working with Harnoor on this project.
1. The pressure residuals are oscillating between values of the order of 1e-8 to 1e-7. Our number of nOrthogonalCorrectors is 1.
2. We have changed our airfoil, and the values of Cl and Cd at alpha=0 are 0.1 and 0.019 respectively. But, the results we are getting are Cl=0.031 and Cd=0.029. We tried switching the BC's to kLowReWallFunction. There is not much change in the values of our lift and drag co-efficients.
3. Sir you misunderstood the question. We are finding difficulty in determining the values of k and omega to be given in initial conditions. Menter's paper in which he proposed the kOmegaSST model, is on this link : https://drive.google.com/open?id=0B3...GEybXNEMXVmY3c
Menter has suggested the following values for freestream k and omega in equation (A11) :
omegainfinity = e*Uinfinity/L
nutinfinity = nuinfinity*d
kinfinity = omegainfinity*nutinfinity
The values of e and d vary from [1,10] and [1e-5,1e-2] respectively.
I have the following data fixed :
Re=235000
c=0.298m
Freestream Turbulent Intensity=0.1%
How do we choose the values of e,d and L? Also, in equation (A12), what does deltay1 mean? In our simulations, we have chosen the values e=5 and d=1e-2.
6. On most of the airfoil, our y+ value is less than 1. Our mesh contains around 800,000 cells. Is it fine enough?
Thanks in advance.
mech_engg_swag is offline   Reply With Quote
Old   November 16, 2016, 08:23
Default C_l and C_d values are incredible high
  #14
Mahe88 is on a distinguished road
Hi all,
I do need help to set up a Simulation of an Airfoil using SimpleFoam and the KOmegaSST model.
I created all the files needed and the simulation is running. However the C_l and C_d values are around something 3e88. which definitely makes no sense.
Maybe somebody could look through my files and give me some hints what is or could be wrong.
I calculated my yPlus which is ~30.
CONTROL DICT
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     simpleFoam;
startFrom       latestTime;
//startTime       0;
stopAt          endTime;
endTime         25;
deltaT          0.1;
writeInterval   10;
purgeWrite      0;
writeFormat     ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision   6;
runTimeModifiable true;
adustTimeStep    yes;
maxCo        0.9;
 functions
    #include "forceCoeffs"
FV Solution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
//Tutorial 2D Airfoil
solvers
    p
        solver          PCG;
    preconditioner  DIC;
        tolerance       1e-06;
        relTol          0.1;
    nSweeps         2;
 pFinal
        $p;
        relTol          0;
    U
        solver          PBiCG;
    preconditioner  DILU;
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.1;
    nuTilda
        solver          PBiCG;
    //preconditioner  DIC;
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.1;
    omega
    solver         PBiCG;
    nSweeps         2;
    tolerance       1e-08;
    relTol        0.1;
    k
    {    solver         PBiCG;
    nSweeps         2;
    tolerance       1e-08;
    relTol        0.1;
SIMPLE
    nCorrectors        2;
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-5;
        U               1e-5;
        nuTilda         1e-5;
relaxationFactors
    fields
        p               0.3;
    equations
        U               0.7;
        nuTilda         0.7;
    omega        0.7;
potentialFlow
    nNonOrthogonalCorrectors 15;
FV Schemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    grad(U)             Gauss linear;
    grad(p)        Gauss linear;
divSchemes
    default                     none;
    div(phi,U)                  Gauss upwind;
    div(phi,k)                  Gauss upwind;
    div(phi,epsilon)            Gauss upwind;
    div(phi,omega)              Gauss limitedLinear 1;
    div(phi,R)                Gauss upwind;
    div(R)                Gauss linear;
    div(phi,nuTilda)            Gauss upwind;
    div((nuEff*dev2(T(grad(U)))))     Gauss linear;
laplacianSchemes
    default                 none;
    laplacian(nuEff,U)      Gauss linear corrected;
    laplacian((1|A(U)),p)         Gauss linear corrected;
    laplacian(alphaTEff,omega)        Gauss linear corrected;
    laplacian(alphaTEff,kt)        Gauss linear corrected;
    laplacian(nu,kl)            Gauss linear corrected;
    laplacian(DepsilonEff,epsilon)    Gauss linear corrected;
    laplacian(DReff,R)            Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda)    Gauss linear corrected;
    laplacian(DomegaEff,omega)        Gauss linear corrected;
    laplacian(DkEff,k)            Gauss linear corrected;
    default             linear;
  interpolate(U)    linear;
snGradSchemes
    default         corrected;
fluxRquired
  default        no;
  p            ;
wallDist
    method meshWave;
Transport Properties
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      transportProperties;
transportModel  Newtonian;
nu              [0 2 -1 0 0 0 0] 3.087e-05;
rho         [1 -3 0 0 0 0 0 ] 1.225;
CrossPowerLawCoeffs
        nu0                 nu0 [ 0 2 -1 0 0 0 0 ] 1e-06;
       nuInf               nuInf [ 0 2 -1 0 0 0 0 ] 1e-06;
        m                   m [ 0 0 1 0 0 0 0 ] 1;
        n                   n [ 0 0 0 0 0 0 0 ] 1;
BirdCarreauCoeffs
        k                   k [ 0 0 1 0 0 0 0 ] 0;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      turbulenceProperties;
simulationType RAS;
RAS
    RASModel            kOmegaSST;
    turbulence          on;
    printCoeffs         on;
//kOmegaSSTCoeffs
//        alphaK1          0.85034;
//        alphaK2          1.0;
//        alphaOmega1      0.5;
//        alphaOmega2      0.85616;
//        gamma1           0.5532;
//        gamma2           0.4403;
//        beta1            0.0750;
//        beta2            0.0828;
//        betaStar         0.09;
//        a1               0.31;
//        c1               10;
//Cmu              0.09;
//wallFunctionCoeffs
//        kappa            0.4187;
//        E                9;
k
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      k;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 1;
boundaryField
    Inlet
    type            turbulentIntensityKineticEnergyInlet;
        intensity       0.000002;
        value           uniform 1;
     Outlet
      { type         zeroGradient;
    Front
       type         empty;//fixed Value,
       //value        uniform 1e-6;
    Back
      type         empty;//fixed Value;
     // value        uniform 1e-6;
    Wing
nut
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nut;
dimensions      [0 2 -1 0 0 0 0];
internalField   uniform 1.54074669e-05;
boundaryField
   Inlet
       type            fixedValue;
        value           uniform 1.54074669e-05;
    Outlet
         type            zeroGradient;
    Front
        type            empty;
    Back
        type            empty;
    Wing
nuTilda
|  \\    /   O peration     | Version:  1.5                                   |
|   \\  /    A nd           | Web:      http://www.OpenFOAM.org               |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      nuTilda;
internalField   uniform 242;
boundaryField
    Outlet
        type            zeroGradient;
    Inlet
        type            fixedValue;
        value           uniform 242;
    Wing
        type            fixedValue;
        value           uniform 242;
    Front
        type            empty;
    Back
        type            empty;
omega
FoamFile
    version     2.0;
    format      ascii;
    object      omega;
dimensions      [0 0 -1 0 0 0 0];
internalField   uniform 30;//5.135822;
boundaryField
    Inlet
      type         fixedValue;
      value        uniform 30;//5.135822;
    Outlet
       type         zeroGradient;
    Front
      type         empty;
    Back
      type         empty;
    Wing
P
FoamFile
    version     2.0;
    format      ascii;
    object      p;
internalField   uniform 0;
boundaryField
   Inlet
        type            zeroGradient; //freestreamPressure;
    Outlet
        type            fixedValue;
    value         uniform 0;
    Front
        type            empty;
    Back
        type            empty;
    Wing
      type        zeroGradient;
U
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (92.61 0 0);
boundaryField
    Outlet
        type            freestream;
        freestreamValue uniform (92.61 0 0);
    //ObenAndUnten
    //    type            symmetry;
    Inlet
        type            freestream;
    Wing
        type            fixedValue;
    Front
        type            empty;
    Back
        type            empty;
Any help is appreciated!!!
Thanks!
Mahe88 is offline   Reply With Quote
airfoil 3d, k omega sst, simplefoam convergence
Convergence issue with continuity equation Jake FLUENT 8 June 6, 2018 03:41
convergence issue laplacianFoam Shakil Masum OpenFOAM Running, Solving & CFD 1 September 9, 2014 13:03
Convergence issue for high speed combustion with radiation. Goutham cet FLUENT 2 July 30, 2014 07:22
SimpleFoam convergence problem with really simple simulation mayank.dce2k7 OpenFOAM Running, Solving & CFD 2 November 19, 2013 05:28
simpleFoam: simple 1-D channel flow, yet very strange convergence behavior kishpishar OpenFOAM Running, Solving & CFD 2 June 20, 2013 13:55
