June 22, 2015, 06:55 |
Janaf Warning
Luca
Rep Power: 10 |
Hi guys,
i'm simulating air-flow in a pipe with janaf thermophysical properties. After few iterations i get the following warning: Code:
smoothSolver: Solving for Ux, Initial residual = 0.0439616, Final residual = 8.21134e-05, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.0322465, Final residual = 6.6714e-05, No Iterations 2 smoothSolver: Solving for Uz, Initial residual = 0.0565688, Final residual = 9.47675e-05, No Iterations 2 DILUPBiCG: Solving for e, Initial residual = 0.956923, Final residual = 0.0387152, No Iterations 1 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 177.597 --> FOAM Warning : From function janafThermo<EquationOfState>::limit(const scalar T) const in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 108 attempt to use janafThermo<EquationOfState> out of temperature range 200 -> 6000; T = 177.349 GAMG: Solving for p, Initial residual = 0.0334125, Final residual = 0.00116066, No Iterations 2 GAMG: Solving for p, Initial residual = 0.00224451, Final residual = 9.06173e-05, No Iterations 2 GAMG: Solving for p, Initial residual = 0.000569202, Final residual = 2.02722e-05, No Iterations 4 time step continuity errors : sum local = 5.47722e-06, global = 1.75769e-07, cumulative = 1.3574e-07 rho max/min : 5.33983 5.33553 smoothSolver: Solving for epsilon, Initial residual = 0.333987, Final residual = 2.81183e-06, No Iterations 2 smoothSolver: Solving for k, Initial residual = 0.340597, Final residual = 3.04902e-06, No Iterations 2 ExecutionTime = 37.59 s ClockTime = 38 s I checked on other threads but i haven't found any useful hint. Boundary conditions and thermophysical properties files are attached. boundaryconditions.zip thermophysicalProperties (copy).zip |
November 24, 2015, 06:48 |
Luca
Rep Power: 10 |
I solved!
The problem was that the initial condition was too far from the solution and the JANAF model suffers of instability. I used a time-variable boundary condition to progressively grow up the velocity till the value requested. |
September 26, 2016, 03:36 |
#3 | |
Fabrizio
Rep Power: 9 |
Hi LucaFen,
I have the same problem. Could you explain me in detail how did you solve this warning? Thank you very much in advance Best regards Fabri Here my warning: Quote:
September 26, 2016, 08:36 |
Luca
Rep Power: 10 |
Hi Fabri,
I changed the BC for the velocity inlet from fixedValue to uniformFixedValue as follows: Inlet { type uniformFixedValue; uniformValue table 2 ( (0 (0 0 0) ) (4500 (300 0 0) ) ); This means that the at each iteration the inlet velocity is increased according to a linear law definined by the initial and final time ( 0 and 4500) and by the velocity values( (0 0 0) and (300 0 0)). in this way I noticed that the solver (rhoSimpleFoam) works better and is more stable. |
[swak4Foam] installation problem with version 0.2.3 | Claudio87 | OpenFOAM Community Contributions | 9 | May 8, 2013 10:20 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Compilation errors in ThirdPartymallochoard | feng_w | OpenFOAM Installation | 1 | January 25, 2009 06:59 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
