when i scale down the down the geometry i get unrealistic result.what is the problem? |
July 30, 2018, 06:27 |
Lolita
Rep Power: 9 |
I am using Ubuntu -14.04, OpenFOAM-4.0, model- multiphaseInterFoam- DamBreak4phase.
I get the result when i use the tutorial as it is, problem starts when i scale down the geometry from metres to millimetres, i get unrealistic results. What could be the problem? |
July 30, 2018, 11:02 |
Robert
Rep Power: 11 |
How do you "scale down"? Did you remember to scale your dimensionless groups accordingly?
If you liked my answer to your question, please consider leaving a "Like" in return |
July 31, 2018, 06:39 |
Lolita
Rep Power: 9 |
I will post the videos of the two cases. Then you give me the feedback
July 31, 2018, 07:27 |
Robert
Rep Power: 11 |
That's a beginning, but the more interesting informationen would be
Last edited by RobertHB; August 1, 2018 at 03:00. Reason: Edited bullet point 3 to not only ask for parameters but also for their values on both scales. |
July 31, 2018, 07:36 |
Nejc
Rep Power: 9 |
Release a droplet on the table or pour a bucket of water on the floor - the result isn't the same.
You have to keep Reynolds number when scaling cases (geometry/viscosity/velocity). In any case, some results will scale linearly, other results won't... |
[ICEM] Problem Meshing Asymmetrical Geometry | Madhatter92 | ANSYS Meshing & Geometry | 1 | December 23, 2017 05:56 |
[ANSYS Meshing] Scale geometry but mesh size to remain same | sangrampp | ANSYS Meshing & Geometry | 1 | February 12, 2016 05:19 |
[Workbench] Problem to select facing when updating geometry | vbernard | ANSYS Meshing & Geometry | 1 | October 28, 2013 09:18 |
[Gmsh] Problem with geometry. | Andrea_85 | OpenFOAM Meshing & Mesh Conversion | 1 | January 6, 2011 08:34 |
Scale Problem and Moving Walls in PCube/TGrid/Fluent | Christian Tollschein | Main CFD Forum | 8 | September 17, 1999 13:01 |
