Understanding an Error Message
Like Tree2Likes
  • 2 Post By alexeym
Old   July 2, 2015, 13:15
Default Understanding an Error Message
Michu
michu is on a distinguished road
Hello All,
I am getting an error while running pisoFoam in openfoam. I attached an image of the error below. I know that "sigFpe" means a division by zero. However, I thought that there should be somewhere in the error message that identifies which script the division by zero is being performed. Can someone help point out where in the error message this would be pointed out?
Also if there are any other indicators inside of the error message that indicate: where the error is/why it happens/ how it takes place/ how to fix it, could you please point it out?
Thank you,
~Michu
michu is offline   Reply With Quote
Old   July 2, 2015, 14:48
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
The error usually means divergence of solution. And since it is in kEpsilon, check you a) BCs, b) mesh.
AshwaniAssam and michu like this.
alexeym is offline   Reply With Quote
Old   July 3, 2015, 09:11
Michu
Hello alexeym,
Thank you for identifying the problem, apparently something is up with my mesh. I am guessing I need at least a certain amount of space between two points. When I tried to move them farther apart, the error went away. Thank you for your help!
Thank you,
~Michu
understanding wmake thanasis OpenFOAM Programming & Development 0 January 11, 2015 14:31
Understanding pimpleFoam convergence criterion Nucleophobe OpenFOAM Running, Solving & CFD 0 March 13, 2013 18:46
Need help understanding an Integral method jwoolsto Main CFD Forum 0 November 9, 2011 16:07
Ambiguity in understanding interfaces in CFX saisanthoshm88 CFX 9 February 2, 2011 14:05
Is this understanding of turbulence models correct? 3kha Main CFD Forum 3 January 31, 2011 21:31
