What is "Allrun" file?
Like Tree5Likes
  • 5 Post By AshwaniAssam
Old   July 4, 2015, 08:11
Question What is "Allrun" file?
venkat
venkat346 is on a distinguished road
can anyone explain about allrun file in openfoam.
1. Why we use this file?
2. How to run this file?
3.After running this file how it will effect the mesh?
Thanks in advance.
venkat346 is offline   Reply With Quote
Old   July 5, 2015, 00:26
Ashwani
AshwaniAssam is on a distinguished road
It is a script file, for running all the commands related to the case it is there. It helps in efficient testing of code. It wound not affect the mesh. You can open it using any editor and see for yourself the commands in it. If you have tried running any case manually, like the icoFoam cavity case, you can easily understand the command in Allrun file.
Now, being a script file it should be run using ./ command, i.e. ./Allrun.
AshwaniAssam is offline   Reply With Quote
Old   July 7, 2015, 03:31
venkat
Thankyou
SparceImage v1.7.x Issue on MAC OS X rcarmi OpenFOAM Installation 4 August 14, 2014 06:42
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 03:23
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
