I can't understand this comment in source code |
July 7, 2015, 07:12 |
xue
Rep Power: 11 |
Hello everyone,
I want to use DPMFoam and I investigated how a particle rebounds when encountering walls: U = U(particle) - U(wall) U -=(1+e)*(U&nw) However, I 'm confused about U(wall), U(wall) is from KinematicCloud.C, line 726, the comment there says "Only wall patches may have a non-zero wall velocity from the velocity field when the mesh is not moving." What does the comment mean?If the bottom of a pipe is wall, U(wall) shall be the velocity of fluid at bottom, though the bottom is not moving!I'm quite confused. Last edited by d849c8; July 7, 2015 at 21:28. |
GPU Linear Solvers for OpenFOAM | gocarts | OpenFOAM Announcements from Other Sources | 37 | August 17, 2022 14:22 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
pisoFoam compiling error with OF 1.7.1 on MAC OSX | Greg Givogue | OpenFOAM Programming & Development | 3 | March 4, 2011 17:18 |
