July 16, 2015, 09:28 |
My "rho max/min" for water is too high
Seokwon Whang
Rep Power: 13 |
I tried to simulate natural convection of water. One of boundary conditions is 'heat flux' //*****************************************// object T; dimensions [0 0 0 1 0 0 0]; internalField uniform 370.15; boundaryField { heater { type compressible::turbulentHeatFluxTemperature; heatSource flux; q uniform 600000000; kappa fluidThermo; kappaName none; Qr none; value uniform 373.15; } ... } //*****************************************// Water properties are like below FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties.water; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectFluid; specie specie; energy sensibleEnthalpy; } mixture { specie { nMoles 1; molWeight 18; } equationOfState { R 3000; rho0 1027; } thermodynamics { Cp 4195; Hf 0; } transport { mu 3.645e-04; Pr 2.289; } } When I check my log file .. the maximum and minimum rho is too high. What can be the problem? //*****************************************// Time = 999 DILUPBiCG: Solving for h, Initial residual = 2.01931e-05, Final residual = 7.45851e-08, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 9.94268e-05, Final residual = 9.33105e-07, No Iterations 2 time step continuity errors : sum local = 0.000207754, global = -1.76408e-09, cumulative = -8.32725e-08 rho max/min : 2103.45 2012.94 DILUPBiCG: Solving for omega, Initial residual = 2.73581e-05, Final residual = 1.06548e-06, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.000215976, Final residual = 1.02418e-05, No Iterations 1 ExecutionTime = 4779.7 s ClockTime = 4813 s Time = 1000 DILUPBiCG: Solving for h, Initial residual = 2.01858e-05, Final residual = 7.45415e-08, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 9.92196e-05, Final residual = 9.55777e-07, No Iterations 2 time step continuity errors : sum local = 0.000213729, global = -8.23112e-10, cumulative = -8.40956e-08 rho max/min : 2103.45 2012.94 DILUPBiCG: Solving for omega, Initial residual = 2.73423e-05, Final residual = 1.06513e-06, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 0.000215784, Final residual = 1.02308e-05, No Iterations 1 ExecutionTime = 4787.59 s ClockTime = 4821 s //*****************************************// |
July 16, 2015, 11:16 |
anonymous
Rep Power: 12 |
You are using a heat flux of 600MW/m2, so the temperature should increase a lot and maybe there are some oscillations in the fields due to enormous gradient in the boundary, do you see any problem with paraFoam?
July 17, 2015, 01:54 |
Seokwon Whang
Rep Power: 13 |
and my boundary condition.. - heater: heat flux 60kW/cm2 >> I will fix it - bottom: zeroGradient - side: zeroGradient - top: *fixedValue 353K...(I think... there is energy inlet(heater), so need to energy out let) Last edited by hswzzz; July 17, 2015 at 21:46. |
July 18, 2015, 10:28 |
Seokwon Whang
Rep Power: 13 |
I fixed the heat flux value. (600MW/m2 to 60kW/m2)
Rho value still is weird... Starting time loop Time = 1 DILUPBiCG: Solving for h, Initial residual = 0.999996, Final residual = 0.0168399, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.999993, Final residual = 0.00707171, No Iterations 6 time step continuity errors : sum local = 0.0283311, global = 9.8679e-16, cumulative = 9.8679e-16 rho max/min : 1027.09 1027.09 DILUPBiCG: Solving for omega, Initial residual = 1, Final residual = 0.000236418, No Iterations 1 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 0.00022971, No Iterations 1 ExecutionTime = 10.16 s ClockTime = 10 s Time = 2 DILUPBiCG: Solving for h, Initial residual = 0.0798506, Final residual = 0.00138049, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.851577, Final residual = 0.00649395, No Iterations 6 time step continuity errors : sum local = 0.0526224, global = 6.31048e-11, cumulative = 6.31057e-11 rho max/min : 1951.39 1918.25 DILUPBiCG: Solving for omega, Initial residual = 0.29705, Final residual = 0.00455358, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.1462, Final residual = 0.00819619, No Iterations 1 ExecutionTime = 15.93 s ClockTime = 16 s Time = 3 DILUPBiCG: Solving for h, Initial residual = 0.024874, Final residual = 0.000482555, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.753727, Final residual = 0.00524751, No Iterations 5 time step continuity errors : sum local = 0.017461, global = -5.93504e-11, cumulative = 3.75537e-12 rho max/min : 2043.82 2007.21 DILUPBiCG: Solving for omega, Initial residual = 0.177789, Final residual = 0.00253689, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.0855762, Final residual = 0.00619617, No Iterations 1 ExecutionTime = 21.43 s ClockTime = 22 s Time = 4 DILUPBiCG: Solving for h, Initial residual = 0.0138778, Final residual = 0.000347565, No Iterations 1 GAMG: Solving for p_rgh, Initial residual = 0.416069, Final residual = 0.00284978, No Iterations 6 time step continuity errors : sum local = 0.00732328, global = -2.89873e-11, cumulative = -2.52319e-11 rho max/min : 2053.06 2016.06 DILUPBiCG: Solving for omega, Initial residual = 0.0994206, Final residual = 0.00140649, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.0575307, Final residual = 0.00440156, No Iterations 1 ExecutionTime = 27.11 s ClockTime = 28 s |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 12:29 |
High Lift Airfoils At High Angles Of Attack | Luiz Pancini | FLUENT | 2 | April 9, 2015 08:01 |
Extremely high Temperature needed to simulate pressurization with rhoCentralFoam | shangzung | OpenFOAM Running, Solving & CFD | 0 | August 6, 2010 06:35 |
High Aspect Ratio elements | Flavio | CFX | 2 | November 24, 2006 12:01 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
