Simulation of Water with buoyantSimpleFoam possible?
Old   July 24, 2015, 05:57
Default Simulation of Water with buoyantSimpleFoam possible?
Benjamin Bergmann
BenFranklinIII is on a distinguished road
Hallo,
I am using the simscale Platform which only offers the buoyantSimpleFoam solve for stationary heat transfer in fluids.
Now I read that buoyantSimpleFoam is for compressible fluids.
I need to simulate water which is incompressible.
Is ist possible to do this with buoyantSimpleFoam ? Or do I habe to use buoyantBoussinesqSimpleFoam which is for incompresible fluids.
The setup I want to simulate is a rod in a tube which is coold by water. The rod is heatet by constant Power do to which the rod reaches a variable temperature depending on the temperatur of the water coming into the system. The tunbs inner wall is considered to be adiabatic.
Can this be simulated using buoyantSimpleFoam and if so how is it done?
Thank you very much best regards.
Benjamin
BenFranklinIII is offline   Reply With Quote
Simulation of dispersion of oil droplets in water -two issues milan.2012 CFX 8 April 12, 2018 18:38
Water wheel simulation Ema40 FLUENT 4 November 13, 2014 02:35
Vertical axis water turbine simulation SHIKHA BHUYAN ANSYS 0 September 16, 2014 01:06
Vertical axis water turbine simulation SHIKHA BHUYAN CFX 1 September 15, 2014 07:40
Boundary Condition question for Cooling Water Pumps Bay Simulation Jaimito FLUENT 0 August 3, 2010 06:58
