Different Pressures on Single and Multiple Processors |
May 23, 2013, 12:27 |
Rep Power: 14 |
Hey Guys
I am having a problem with the pressure on parallel simulations; I get different pressures when I am running on multiple processors. I have tried PCG and GAMG solvers. Any ideas? |
May 24, 2013, 02:32 |
Nima Samkhaniani
Rep Power: 24 |
represent your results by a contour maybe help
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
May 18, 2014, 20:20 |
compressibleInterFoam
Rep Power: 12 |
Hi !
I think I face a similar problem. I worked several months on simualtion of cavitation bubbles and started with the compressibleInterFoam solver and modified it, but the problem still also remains with the original one(s) (versions: 2.1.1, 2.2.1, 2.3.0): When at least one of the processor patches crosses the interface, the velocity field is not computed correctly. You observe numerical fragments parallel to the patch like in the following picture https://www.dropbox.com/s/a4cr4qpyoqjhue2/bug.png The only version I discovered to be able to deal with the decomposition is the openfoam-extend version. Has anyone observed this? Is this the same error as discussed here? Furthermore I discovered that even without decomposing, running a 2D axis-symmetric case has some overestimating properties in the cell of the interface directly at the axis. So if you place a bubble that will collapse onto the axis, it will unphysically get thinner at the axis. This also seems to be no problem in the extend version 3.0 (absolutely same input files). Regards, Max |
October 17, 2015, 15:59 |
#4 | ||
Rep Power: 12 |
Display Modes | |
saving Transient/Unsteady data of multiple surface integrals in single file | ankur gupta | FLUENT | 0 | February 22, 2012 13:59 |
Single Hydraulic diameter for multiple holes | thatoneguy | Main CFD Forum | 0 | April 5, 2010 12:58 |
Problem on multiple processors..works fine on single processor! | skabilan | OpenFOAM Running, Solving & CFD | 2 | December 5, 2009 12:19 |
Multiple domain interfaces on a single surface | mike | CFX | 2 | January 26, 2009 17:03 |
Output multiple hardcopies into a single PS file | Winston Lin | FLUENT | 0 | September 16, 2003 18:06 |
