PorousMedia Problem with Temperature Distribution
Old   July 18, 2008, 06:48
Default I am trying to simulate the st
Pawan
pawan is on a distinguished road
I am trying to simulate the steady turbulent fluid flow through Porous region in a converging-diverging pipe. The porous media extend from the end of diverging section to start of converging section as showing in image .
I am using rhoImplicitPorousSimpleFoam
Turbulence Model
k-Epsilon model is used
Boundary condition
Inlet:
mass flow Inlet = 0.417 kg/s
Total Temperature = 811K
Outlet:
Pressure Outlet = 15000 Pa (gauge pressure)
Wall:
Insulated
ThermoPhysical properties are same in both fluent and openfoam.
mixture
air 1 28.966 1006.43 0 1.789e-05 0.74417
Porous Region coeff
i j k
d =4.67e+07 4.67e+09 4.67e+09
f = 10 1000 1000
Problem(doubt)
Under steady state , fluent show a temperature range of 809-811K , while in openfoam this range extend form 791-811 K . as showning fig and
AS wall is insulated , and there is no such energy loss, such large temperature drop should not be there logically.
However Other variable as pressure, velocity show the trend and range same as in fluent .
Can anyone explain this behavior or point out where am i wrong in setting case ?
pawan is offline   Reply With Quote
Old   May 10, 2010, 06:12
Default The same like me
Chrisi1984 is on a distinguished road
Hi!
How have you solved the problem?
I have the same problem with porous media.
My pressure and velocities are very similar to the results of fluent, but my temperature field is looking different.
Greets Chris
Chrisi1984 is offline   Reply With Quote
Old   August 2, 2015, 23:08
Ipos
Kittipos is on a distinguished road
Hi
I used OpenFoam and I have a problem same as you.
Could you describe to me pls.
Thx
Kittipos is offline   Reply With Quote
Cryosurgery - temperature distribution problem Tal FLUENT 3 October 18, 2010 15:58
Temperature distribution in a solid michael_krobath OpenFOAM Running, Solving & CFD 3 August 29, 2007 07:12
temperature distribution in a plate with 2 metals Amir Khodabandeh FLUENT 1 March 16, 2007 02:51
Temperature local distribution on the boundary Matteo Siemens 0 January 10, 2007 07:18
Linear Temperature Distribution Kathir FLUENT 0 July 16, 2004 09:33
