August 6, 2015, 05:26 |
cyclic bc for airfoil error
Rep Power: 10 |
Hello everyone,
Now I am simulating flow around a 3D airfoil in OpenFOAM, and I use the C shape grid. i should define the bc used to be empty in 2D case into cyclic, but when I use createPatch, there is error like this: Code:
Create time Create polyMesh for time = 0 --> FOAM FATAL ERROR: face 4802 area does not match neighbour by 199.99% -- possible face ordering problem. patch:back my area:0.0236307 neighbour area:979.863 matching tolerance:0.0001 Mesh face:684334 fc:(1.0005 88.1846 0) Neighbour fc:(179.267 88.1846 1) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 221. FOAM exiting Code:
FoamFile { version 2.0; format ascii; class polyBoundaryMesh; location "constant/polyMesh"; object boundary; } 4 ( airfoil { type wall; nFaces 2352; startFace 677180; } back { type cyclic; nFaces 9604; startFace 679532; neighbourPatch front; matchTolerance 0.0001; transform noOrdering; } farfield { type patch; nFaces 7056; startFace 689136; } front { type cyclic; nFaces 9604; startFace 696192; neighbourPatch back; matchTolerance 0.0001; transform noOrdering; } ) Code:
pointSync true; patches ( { name front; patchInfo { type cyclic; matchTolerance 0.0001; neighbourPatch back; transform noOrdering; } constructFrom patches; patches (front); set f0; } { name back; patchInfo { type cyclic; matchTolerance 0.0001; neighbourPatch front; transform noOrdering; } constructFrom patches; patches (back); set f0; } ); Thanks a lot. |
August 6, 2015, 07:17 |
Rep Power: 10 |
now I tried foamUpgradeCyclics and it splits my plane into two parts, then I changed my createpatchDict follow the new generated boundary file,
pointSync true; matchTolerance 0.2; // Patches to create. patches ( { name front_half0; patchInfo { type cyclic; neighbourPatch front_half1; transform noOrdering; } constructFrom patches; patches (front_half0); matchTolerance 0.2; //set f0; } { name front_half1; patchInfo { type cyclic; neighbourPatch front_half0; transform noOrdering; } constructFrom patches; patches (front_half1); matchTolerance 0.2; //set f0; } { name back_half0; patchInfo { type cyclic; neighbourPatch back_half1; transform noOrdering; } constructFrom patches; patches (back_half0); matchTolerance 0.2; //set f0; } { name back_half1; patchInfo { type cyclic; neighbourPatch back_half0; transform noOrdering; } constructFrom patches; patches (back_half1); matchTolerance 0.2; //set f0; } ); Code:
Create time Create polyMesh for time = 0 --> FOAM FATAL ERROR: face 0 area does not match neighbour by 0.122856% -- possible face ordering problem. patch:back_half0 my area:0.0236017 neighbour area:0.0236307 matching tolerance:0.0001 Mesh face:679532 fc:(0.999501 -88.1895 0) Neighbour fc:(1.0005 88.1846 0) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 221. FOAM exiting |
August 7, 2015, 07:42 |
Rep Power: 10 |
problem solved!
thanks for http://www.cfd-online.com/Forums/ope...tml#post378087 I really appreciate your help! |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
POSDAT problem | piotka | STAR-CD | 4 | June 12, 2009 08:43 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 20:50 |
