August 14, 2015, 11:05 |
MULES with axial symmetry (wedge+empty BC)
Robert Sawko
Rep Power: 22 |
Dear OpenFOAM users and developers,
I am trying to run a simple pipe with constriction and axial symmetry. Something fairly similar to the geometry posted here [1]. The solver I am using is twoPhaseEulerFoam but I observed similar behavior in interFoam too. My inlet condition is uniform for all quantities and for alpha I am setting something 0.015. The wedge and empty BC are applied on the the sides and at the centre line respectively e.g. my alpha BC looks like this Code:
boundaryField { outlet { type inletOutlet; inletValue uniform 0; } walls { type zeroGradient; } inlet { type fixedValue; value uniform 0.02; } front { type wedge; } back { type wedge; } axis { type empty; } } After this all sort of evil begins to occur. Viscosity there goes up, velocity develops a completely different profile than in the 3D case and Co number increases gradually. I checked the case several times now and a 3D equivalent works. Single phase solvers work with this setup too so my guess is that multiphase solver is the culprit. My guess is that MULES is causing the problem here, but I cannot be sure. Please let me know if you have any suggestions on how to fix it. Can post a more detailed setup. [1] http://openfoamwiki.net/index.php/Contrib/MakeAxialMesh |
Display Modes | |
Free Surface Ship Flow | timfranke | OpenFOAM Running, Solving & CFD | 322 | March 3, 2021 09:04 |
[snappyHexMesh] sHM quality of multi-region | aminem | OpenFOAM Meshing & Mesh Conversion | 0 | April 16, 2015 11:38 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
Differences between serial and parallel runs | carsten | OpenFOAM Bugs | 11 | September 12, 2008 11:16 |
