WernerW |
August 18, 2015 17:30 |
Rotating Mesh with pympleDyMFoam
5 Attachment(s)
Dear Forum,
I'm trying to simulate the performance of a Wind turbine with pimpleDyMFoam and I'm following the tutorial incompressible/pimpleDyMFoam/propeller. I'm running the model with the Allrun script and I think I'm doing everything as in the tutorial but when I generate my Mesh and even when I run the solver I can't see the wind turbine rotating. Futhermore the whole BlockMesh rotates as the simulation runs, which is very strange.
Has anyone faced this kind of problem ?
I'm pasting my snappyHexMesh,
castellatedMesh true; // make basic mesh ?
snap true; // decide to snap back to surface ?
addLayers true; // decide to add viscous layers ?
geometry // Load in STL files here
RotorAsm.stl // STL filename
type triSurfaceMesh;
name rotor;
regions
ascii
name rotor;
Cylinder.stl
name Cylinder;
regions
ascii
name Cylinder;
// Settings for the castellatedMesh generation.
castellatedMeshControls
maxLocalCells 1000000; //max cells per CPU core
maxGlobalCells 2000000; //max cells to use before mesh deletion step
minRefinementCells 10; //was 0 - zero means no bad cells are allowed during refinement stages
maxLoadUnbalance 0.10;
nCellsBetweenLevels 3; // expansion factor between each high & low refinement zone
// Explicit feature edge refinement
features
{ file "RotorAsm.eMesh"; level 2;}
{ file "Cylinder.eMesh"; level 2;}
// Surface based refinement
refinementSurfaces // Surface-wise min and max refinement level
rotor {level (2 2);}
Cylinder {
level (2 2);
faceType boundary;
cellZone Cylinder;
faceZone Cylinder;
cellzoneInside inside;
} // Surface-wise min and max refinement level
resolveFeatureAngle 30; // Resolve sharp angles
// Region-wise refinement
refinementRegions // In descending levels of fine-ness
Cylinder
mode inside;
levels ((1E2 2));
locationInMesh (50.31415912 100.31415912 100.31415912);
allowFreeStandingZoneFaces false;
// Settings for the snapping.
snapControls
nSmoothPatch 3;
tolerance 4.0;
nSolveIter 30;
nRelaxIter 5;
nFeatureSnapIter 10; // default is 10
// New settings from openfoam 2.2 onwards for SHMesh
implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract
explicitFeatureSnap true; // default is true
multiRegionFeatureSnap false; // default is false - detects features between multiple surfaces
// Settings for the layer addition.
addLayersControls
relativeSizes true; // was true
layers
rotor {nSurfaceLayers 1;} // was 3
expansionRatio 1.3;
finalLayerThickness 0.3; //was 0.00016
minThickness 0.1; //was 0.00008
nGrow 1; // was 1
// Advanced settings
featureAngle 80; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle.
nRelaxIter 3; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh.
nSmoothSurfaceNormals 1; // Number of smoothing iterations of surface normals
nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction
nSmoothThickness 10; // Smooth layer thickness over surface patches
maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells
maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large
minMedianAxisAngle 90; // Angle used to pick up medial axis points
nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations
nLayerIter 50; // Overall max number of layer addition iterations
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minFlatness 0.5;
minVol 1e-13;
minTetQuality -1;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.05;
minVolRatio 0.01;
minTriangleTwist -1;
// Advanced
nSmoothScale 4;
errorReduction 0.75;
relaxed
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 75;
// Advanced
//debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
DynamicMeshDict
dynamicFvMesh solidBodyMotionFvMesh;
motionSolverLibs ( "libfvMotionSolvers.so" );
solidBodyMotionFvMeshCoeffs
cellZone Cylinder;
solidBodyMotionFunction rotatingMotion;
rotatingMotionCoeffs
origin (0 0 0);
axis (1 0 0);
omega 158; // rad/s
and my U
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
//- Set patchGroups for constraint patches
#includeEtc "caseDicts/setConstraintTypes"
inlet
type fixedValue;
value uniform (7.5 0 0);
outlet
type inletOutlet;
inletValue $internalField;
value $internalField;
sides
type zeroGradient; //freestream;
//$internalField;
rotor
type movingWallVelocity;
value uniform (0 0 0);
files and a couple of images.
Thanks in advance for your help.
