Flow Past a cylinder- Re-1000-PisoFoam Solver
1 Attachment(s)
Hello All,
I know this is awell discussed topic with a lot of posts in the forum. I believe I have done due diligence about going through the posts. I am also new to OpenFoam. So please bear with any incompetence if any. I am trying to simulate the 3D flow past cylinder at re=1000 using scalable and no wall functions but with little success. I am using RANS modelling K-epsilon and SST k-Omega. My drag values are around 0.84 but I dont capture any vortex shedding and my cl values are very low. I know that for that no wall fucntion my Y+ should be less than 6 and I have checked that using YplusRAS utility in openfoam. FOr scalable wall functions my Y plus is around ~ 12. I am using gmsh to create my mesh. Please find below all the value that I have used for scalable wall function. k is calculated as 1.5(Velocity*Intensity)^2 Intensity=0.16*RE)^-1/8 ( http://www.cfd-online.com/Wiki/Turbu...ary_conditions) Epsilon - as calculated in the above refernce and has a valueof 5.17E-07 Omega =1.347 and Omega near wall 200 I am attaching my geo file as mesh.txt p at 0 seconds boundaryField { top { type zeroGradient; } bottom { type zeroGradient; } inlet { type zeroGradient; } outlet { type fixedValue; value uniform 0; } frontAndBack { type zeroGradient; } cylinder { type zeroGradient; } } U=0 boundaryField { top { type slip; } bottom { type slip; } inlet { type freestream; freestreamValue uniform (0.025 0 0); } outlet { type inletOutlet; inletValue uniform (0 0 0); value uniform (0 0 0); } frontAndBack { type slip; } cylinder { type fixedValue; value uniform (0 0 0); } } k= boundaryField { top { type kqRWallFunction; value uniform 0; } bottom { type kqRWallFunction; value uniform 0; } inlet { type fixedValue; value uniform 4.286E-06; } outlet { type zeroGradient; } frontAndBack { type kqRWallFunction; value uniform 0; } cylinder { type kqRWallFunction; value uniform 0; } } Epsilon boundaryField { top { type epsilonWallFunction; value uniform 5.174E-07; } bottom { type epsilonWallFunction; value uniform 5.174E-07; } inlet { type fixedValue; value uniform 5.174E-07; } outlet { type zeroGradient; } frontAndBack { type epsilonWallFunction; value uniform 5.174E-07; } cylinder { type epsilonWallFunction; value uniform 5.174E-07; } } Will appreciate nay suggestions |
Any thing wrong with the way I have posted my question??.. Just wondering about the lack of response.. Please let me know if any specific information is required.
Hey Vito,
Sometimes the questions get lost in the forums and nobody answers them :/ ... Don't know if you are still interested in the solution for your problem since it has been a while, but anyways. I've been doing simulations with flow past cylinder using k-epsilon. What I found out is that it can take a very long time to the vortex-street to form, so perhaps leave your simulation running for quite a bit and check if the instability gradually building up (look for wiggles at the nut variable). In my case, I simulated flow past a cylinder with Re 3900, with an inlet velocity of 1 m/s and the appropriate kinamtic viscosity (to match the Re), and I only saw the vortices after the 80th second or so. I havent looked at your mesh, but if this doesnt work let me know. Regards |
Thanks for getting back davi. Thi sis interesting becasuse I used k omega for re =3900 and simulated the flow up to 120 seconds and saw the formation of vortex street. I have not tried k epsilon, but after you have mentioned that you do indeed see the formation os the street I am curiopus to try it now.
There is another post where I have plotted the variation of cd with time find below http://www.cfd-online.com/Forums/showthread.php?t=158661&goto=newpost I am not quite sure if the value of cd has converged as I see some divergence later on. What is your take on the plot ?? |
Ok, so I will post some of my results in a bit. By the looks of your graph, it actually seems to be going correctly. In my results, the drag starts out with a jump, than stays steady, then grows until it reaches a steady point and stops (but the wiggles continues due to the vortex street). So you should just run the simulation for larger times. I ran my for 200 seconds, so just I could be sure the results had finally settled.
Your simulation is 3D right? Have you tried a 2D or did you start with 3D? If you are going to use k-epsilon, the wall function is a very important and to get results close to the experimental ones you should get a really refined mesh around the cylinder. |
My simulation is 3d. Yes I am trying to keep a refined mesh around my wall. In the case of K omega where I used no wall functions my y plus values are around 6 , Oh and btw The plot that i have put up is with a pimple foam solver, i found out that pimplefoam is faster than pisofoam ofcourse when the number of outercorrectors is one then pisofoam is same as pimplefoam
1 Attachment(s)
I havent played much with k-omega. Regarding k-epsilon, I used the same values of inlet as you did based on the cfd-online formulations. I also used pimpleFoam to run my cases.
As you can see in the graph, my drag coeff follows a similar trend as the one you posted, so just run during a longer period. By the way, these are for 2D cases, but it shouldnt be much of a difference. Let me know how it goes. Oh, and if you manage to get the fluid to behave properly, but the final values of drag and lift are different from the literature, you might want to try to increase the size of your domain. I found out that if you put your boundaries somewhat close to the cylinder, they have a big impact on the final result. |
1 Attachment(s)
Davi Lookin gat your plots they seem to follow the behavior correctly trendwise, Albeit value of cd is a little less than what it should be but then RANS also underpredicts cd slightly correct??
Now I have my completed plot below. You see how it wiggles but does not folow a straight path as in it has a low frequency motion to it as well, nO wi am not sure how to explain that. My Cl plot howver looks ok to me. It is just that cd is not reaching steady state and i have run ot up to 120 seconds, i just did not want to run any longer as i did not believe it would make a difference. Btw 2d and 3d modelling and simulation does not accoutn for diffrence in the results I would say. Sorry I did not crop the image. Your thoughts |
1 Attachment(s)
You seem to have a second harmonic going on... How many cells does your mesh have? Can you post a picture of the whole domain from paraview? As I said, the domain size impact greatly in the results. Also, in my boundary conditons, I use kqRWallFunction with the same value as the inlet.
Indeed, the Cd is a bit lower, but not by much. Comparing with other numerical simulations and considering the experimental variability, it is pretty spot on. Also, in the papers I have read they say that the 3D simulations do differ a bit from 2D due to tri-dimensional vortices formations... Here is the plot of the simulations I ran with different Re, with low re I just ran laminar cases, as you can see, the results are pretty reasonable to me (the results are also close when comparing Strouhal and Lift). |
2 Attachment(s)
Please find attached my meshes. I mean if were to go finer what is the point of RANS itself when i can go ahead and use LES??.
So i guess instead of using 0 k everywhere else I should the same value as inlet right which is th eorder od e^-05 What is impressive is you have seemd to get it spot on even at 10^6 reynolds number .. |
2 Attachment(s)
Your mesh seems fine enough to be getting the correct flow behavior, although, it would need finner cells close to the cylinder to get a Cd around 5% of the experimental (just a guess). So I'm posting my mesh, so you can take a look. I think the height (y-axis) of your mesh might be a bit too low...
What about the Z-axis? What is the size of it? I saw that you put frontAndback with velocity 'slip', but for k and epsilon you chose frontAndback with wall functions (kRWallFunction)... I think you should try zeroGradient. I would guess that this boundary condition is the culprit. |
My mesh size in the z direction may be little coarse so I have 20 cells over a length of 0.4 units.
I am going to try and implement all the suggestions that you have given me and will post how it all goes. Would like to thank you for your time and effort. vito |
Your Z is only 0.4 ? Isnt that too small? I think these might be causing the problems in your simulation. You should try 2D, or 3D with a larger Z.
Did you manage to get the proper results?
Hi Davi,
I am sorry I could not reply earlier. I refined the mesh both streamwise and spanwise and used LES one eqn eddy and i got good results. I suspect all my trouble was due to coarse mesh which caused all the issues.:D:D. I am beginning to explore LES now. |
Good to know. Good luck on your work!
Thanks a lot for your help once again davi..
Hey Vito, could you post your case here? Im thinking of trying some LES too, but my early results are not coming out good.
Hey Davi,
Sure, When you say post your case, do you mean the problem statement or anything else in particular ?? Are you trying 3d or 2d ?? |
Im still doing some 2D, but slowly trying 3D cases, cause I read that for flows around Re 1000 to 1e5 the tridimensional effects are considerable and in this range the RANS models are not predicting well (in literature are many reports saying that rans do not perform well in such region).
But what Im looking for now is just the set up for the LES case, but somethings I still havent figured, like: how refined should be the mesh and the impact of local refinement in the overall result; and what time-step should I use. Perhaps you can help me with those. Could you post your mesh (3D or 2D)? Cheers |
