How to calculate the smallest resolved time scale from a LES run in OpenFOAM? |
August 31, 2015, 09:42 |
Mohsen KiaMansouri
Rep Power: 16 |
Hello all Foamers
I usually choose the time step in LES based on the CFL number to be less than unity (or 0.5) in order to have a stable run. Now, I want to calculate the smallest resolved time scale in my LES run to check whether the selected time step is suitable or not. Any one can help me how to do that?
“If you have an apple and I have an apple and we exchange these apples then you and I will still each have one apple. But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.” |
September 2, 2015, 05:00 |
Rep Power: 12 |
September 2, 2015, 07:21 |
Kapa Lilla
Rep Power: 17 |
the smallest resolved time scale present in your simulation only can be approximated based on the numerical scheme you are using. A rule of thumb is that for a 1st order scheme you need 25 nodes/wavelength, for a 2nd order scheme appr. 16 nodes/wavelength (for standard schemes). This means: your scheme gives you NPW - number of points per wavelength your mesh size is DX Then the resolved wavelength can be calculated as: k = 2*PI/(NPW*DX) From wavelength you can calculate the resolved frequency: f = k*c/(2*PI) where c is the problem's propagation speed: incompressible simulation - flow speed, compressible simulation: sound speed. Again, this is only a theoretical approximation. If you really want to know exactly what scales you resolve and what not, plot the energy spectrum in some points and that gives you directly the cut-off frequency. Best, Lilla |
September 3, 2015, 06:02 |
Rep Power: 12 |
I think I missunderstood the question :-) Thanks killa for your answer
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field | lakeat | OpenFOAM Community Contributions | 58 | December 23, 2021 02:36 |
Map of the OpenFOAM Forum - Understanding where to post your questions! | wyldckat | OpenFOAM | 10 | September 2, 2021 05:29 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
advection time scale | Tanveer ahmad Rubani | CFX | 1 | February 24, 2009 16:16 |
