November 24, 2016, 08:38 |
#101 |
Wojciech Gołąbek
Rep Power: 12 |
I used fe-3.1 in my case and I have some problems to run your case on it...
Your mesh (fluid) is very rough, especially in the space between the "pumpkin" and "bamboo tubes" where you can assume to get really high velocity. You need to make more than 3 elements in X direction (and I would also add few in Y direction). IMO you need at least 5 elements in X direction (but it's still not enough to get good results) to test this case. You need also to create better mesh transition between blocks (I've already wrote sth about it in this topic). Also I don't think that starting your tests with 10 m/s is good idea. If I were you I would use 0.5 m/s (or even less then it) to see how it'll work (courant number, displacements, forces, ect.). It will be easier to improve your mesh and then you will try to find good time step for you main problem. Kind regards Wojciech |
November 24, 2016, 08:43 |
#102 | |
ok
Rep Power: 13 |
don't worry, I will have a look. My case implemented in fe31, but never mind I will try to get some time to study your case. For any further information or to remind me contact via may78may@hotmail.com. Because sometimes I'm taking long and don't check the forum. All the best Maimouna |
November 27, 2016, 11:14 |
#103 |
Karthick
Rep Power: 9 |
Hai,
That's right Wojciech!! Thanks for the suggestion. It really helped me a lot. I added 5 elements along X direction and 3 elements along Y direction and Inlet Velocity set to (-0.25 0 0). The simulation runs with no deflection of plate until 2 seconds. After 2 seconds I see the deflection of the point as follows. 2.00001 2.85381e-09 -2.58931e-09 4.7758e-23 2.00002 2.53603e-09 -6.97833e-09 -9.52907e-24 2.00003 -1.7756e-07 -3.69658e-07 -8.22465e-23 Until 2.00003 s, the courant number max is below 0.2, but at 2.0004 s the Max Courant number shoots up to 22.3112 (with velocity magnitude 149 m/s) in iteration 15 and to 2499.58 (with velocity magnitude 450 m/s) in iteration 16 and the simulation had stopped. 1. Could you find possible reasons for this? I think as the plate starts deflecting, the velocity near the gap goes up (2 way coupling) and this can cause the Co number go high. In that case, how should I avoid this? And what time step would you advise me? With 0.00001 time step it took 15 hours on my laptop. 2. My aim is to do compressible fsi for my setup along with LES modelling. So I have planned to work on HronTurek tutorial case first towards compressible fsi (which I have no idea how to implement it) and then applying it on my case. How would you advise me to carry this out in general? Since fsiFoam is based on pisoFoam solver (incompressible), does it involve tedious coding stuff for me to do compressible fsi for my setup? Thanks for spending time to study my case @Maimouna. And also for the mailID Thank you for helping me out!! Karthick |
November 27, 2016, 12:09 |
#104 |
Wojciech Gołąbek
Rep Power: 12 |
1. I had similar problem in my case (It took me really a lot of time to find solution). Adding turbulence model solved it so try it.
2. IMO the easiest way to do this will be manually adapt solver which already exist in OpenFOAM. Here you cane find some information how to do it: http://www.tfd.chalmers.se/~hani/kur...es_vyzikas.pdf http://www.tfd.chalmers.se/~hani/kur...FlowReport.pdf Even if you do not know C ++ very well you still should relatively easy handel it. I do not know if you ever used LES but this simulation can take much more time than you think In my case (it was 3D case with really complicated geometry, k-omega model and time step: 1e-7 [s]) it took me almost two months to get results for 1.5e-4 [s] (in my case fluid domain: 579 968 elements and solid domain: 32 256 elements). LES with good mesh even in 2D can take lots of time. Time step dependent on mesh sieze and Courant number so the best way to find it is a trial and error method. You have a constant velocity (at least I suppose) on your inlet, so it won't be take too much time to find it. Last edited by Woj3x; November 29, 2016 at 09:46. |
November 30, 2016, 03:55 |
#105 | |
Karthick
Rep Power: 9 |
Thanks for sharing the documents. That Indeed helped me to understand how the headerfiles are linked in fsi and how fsi library is connected to central installation of foam extend. In the document, he has implemented interflow model built from interDymFoam. So I will just quickly write down the procedure required in my case of building rhoPimpleFlow model from rhoPimpleFoam. 1. Initially the src/fluidStructureInteraction/flowModels/pisoFlow files are copied and created rhoPimpleFlow as described and compiled after adding the flow model path to Make/files file. 2. On comparing with rhoPimpleFoam solver, I have to add the missing header files to the rhoPimpleFlow. So I included turbulenceModel.H, bound.H to rhoPimpleFlow.C and basicPsiThermo.H to rhoPimpleFlow.H and compiled it again. I did this. 3. Now I have to write down the fields (from CreateFields.H in solver directory) into rhoPimpleFlow.C and declare it in the rhoPimpleFlow.H. So I planned to add field one by one and compile it. Here is the first field in CreateFields.H Code:
autoPtr<basicPsiThermo> pThermo ( basicPsiThermo::New(mesh) ); basicPsiThermo& thermo = pThermo(); volScalarField& p = thermo.p(); volScalarField& h = thermo.h(); const volScalarField& psi = thermo.psi(); Code:
pThermo_ // added ( basicPsiThermo::New(mesh) ), basicPsiThermo& thermo_ = pThermo(), volScalarField& p = thermo.p(), volScalarField& h = thermo.h(), const volScalarField& psi = thermo.psi(), It showed some errors as ‘Foam::basicPsiThermo’ is not a direct base of ‘Foam::flowModels::rhoPimpleFlow’ and also other errors. I have attached below both .H and .C file along with log file. This field is not similar to U or p field, so I got stuck with this. I am going to need more help before Implementing rhoPimpleFoam I suppose!! Could you please tell where lies the problem or is there any problem with my way of approach. As in, do I have to understand everything in the solver code and then code it one by one. Also if I can learn better about all these, please share it. Thanks, Karthick |
November 30, 2016, 10:06 |
#106 |
Wojciech Gołąbek
Rep Power: 12 |
December 1, 2016, 13:04 |
#107 |
Karthick
Rep Power: 9 |
Hai,
Thanks for the suggestion. I think I should learn PISO algorithm ---> how the those equations are coded in icoFoam solver-----> how the turbulence equations are added to icoFoam to form PisoFoam solver ---> finally adding compressibility factor to form rhoPisoFoam solver And gain knowledge of codes behind icoFlow and pisoFlow models in FSI library (which are directly based on icoFoam and pisoFoam solvers). With this knowledge, I hopefully can implement rhoPisoFlow or rhoPimpleFlow as a flow model. Thanks for the help!! Karthick |
December 1, 2016, 13:23 |
#108 |
Wojciech Gołąbek
Rep Power: 12 |
It's probably the best approach you can make now.
I could only tell you that codes behind icoFoam and pisoFoam are pretty simple so you should do it this rather fast. The only difference between pisoFlow and pisoFoam is that the time loop is out from pisoFlow (in fsiFOAM algoritm). You also need to find how the algorithm for transferring data between solid and fluid solvers work (this is probably the most important thing to adapt rhoPimpleFoam). Kind regards, Wojciech |
December 15, 2016, 10:29 |
#109 |
Karthick
Rep Power: 9 |
Hai,
Finally I was able to implement rhopisoFlow into FSI library. It indeed required quite some effort to make it work, but learnt a lot trying to implement this. I checked the model with HronTurek fsi tutorial and I could simulate it under compressible flow conditions. Thanks @Wojciech @Maimouna for all the help. Now it's time to run it on my application. Regards, Karthick |
December 25, 2016, 06:12 |
#110 |
Karthick
Rep Power: 9 |
Hai,
A quick question! I am running the HronTurekFSI with implemented compressible flow model. I can the deflection of the flag, but it waves slightly below the center, it doesn't wave about the center axis. I am confused whether is it the effect of compressibility factor or am I doing anything wrong. I couldn't find how a HronTurek case behaves under compressible case to check my simulation is correct or wrong! can any1 help me out on this! I have attached the deflection plot down below! Thanks, Karthick |
April 21, 2017, 09:41 |
#111 |
GS
Rep Power: 10 |
Yes. This is an issue with geometry.
You seem to be using "blockMesh" utility of openFoam. You need to check the specified directions for the patches in blockMeshDict file. |
March 27, 2019, 14:15 |
#112 |
Hojatollah Gholami
Rep Power: 7 |
Dear Singh
I run FSI2 of hronTurek Benchmark with fsiFoam. the problem is when deflection increase the solution diverge (velocity increasing). Do you any recommend for fvScheme ond fvSolution? Last edited by Hgholami; March 28, 2019 at 08:35. |
April 20, 2019, 21:11 |
validation of fsiFoam
#113 |
Hojatollah Gholami
Rep Power: 7 |
Dear wyldckat,
In fsiFoam solver the tutorial of Hron-Turek (FSI3) with default blockMeshDict have 12% error compared with article. With other blockMeshDict (available in tutorial with finner mesh and 0.0005 deltaT) the deflection of beam reduces and deflection is lower. Do you know, the problem is in OpenFOAM solver or the case of "Hron-Turek"? Thanks |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
