September 11, 2015, 00:05 |
SonicFoam printStack Error
Hi all,
I am trying to run an intensive simulation with supersonic velocities and high temperature. Whenever I attempt to increase the temperature or speed, I get an error. In the case I have below, the program ran but died after a few steps. In the past, I have tried to no avail to solve this problem by changing the value in: ~/thermophysicalModels/specie/lnInclude/thermoI.H at line 76 Are there any ways to edit the thermophysical properties to allow for more heat? Or is this a problem of disk space? Thanks! Time = 3.5e-05 Courant Number mean: 0.000722438 max: 0.632063 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 0.0839927, Final residual = 4.41532e-06, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.0510721, Final residual = 3.37884e-06, No Iterations 4 DILUPBiCG: Solving for e, Initial residual = 0.038889, Final residual = 8.06531e-07, No Iterations 3 DILUPBiCG: Solving for p, Initial residual = 0.0416342, Final residual = 3.71647e-11, No Iterations 4 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 1.1378e-12, global = 9.65176e-14, cumulative = -1.36379e-11 PIMPLE: iteration 2 DILUPBiCG: Solving for Ux, Initial residual = 0.045368, Final residual = 6.08536e-06, No Iterations 11 DILUPBiCG: Solving for Uy, Initial residual = 0.024744, Final residual = 5.53074e-06, No Iterations 9 DILUPBiCG: Solving for e, Initial residual = 0.0354167, Final residual = 7.05416e-06, No Iterations 11 DILUPBiCG: Solving for p, Initial residual = 0.026016, Final residual = 8.87562e-09, No Iterations 3 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 time step continuity errors : sum local = 2.90647e-10, global = 8.57064e-11, cumulative = 7.20684e-11 DILUPBiCG: Solving for epsilon, Initial residual = 0.276884, Final residual = 6.09947e-09, No Iterations 20 DILUPBiCG: Solving for k, Initial residual = 0.232956, Final residual = 4.11722e-09, No Iterations 22 ExecutionTime = 65 s ClockTime = 65 s Time = 4e-05 Courant Number mean: 0.000754311 max: 5.18107 diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0 PIMPLE: iteration 1 DILUPBiCG: Solving for Ux, Initial residual = 0.0767201, Final residual = 6.22788e-06, No Iterations 4 DILUPBiCG: Solving for Uy, Initial residual = 0.0416175, Final residual = 3.18463e-06, No Iterations 4 DILUPBiCG: Solving for e, Initial residual = 0.0311735, Final residual = 7.26361e-07, No Iterations 3 --> FOAM FATAL ERROR: Maximum number of iterations exceeded From function thermo<Thermo, Type>::T(scalar f, scalar T0, scalar (thermo<Thermo, Type>::*F)(const scalar) const, scalar (thermo<Thermo, Type>::*dFdT)(const scalar) const, scalar (thermo<Thermo, Type>::*limit)(const scalar) const) const in file /home/openfoam/OpenFOAM/OpenFOAM-2.3.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 76. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 Foam::species::thermo<Foam::hConstThermo<Foam:er fectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::TEs(double, double, double) const at ??:? #3 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? #4 Foam::hePsiThermo<Foam:siThermo, Foam:ureMixture<Foam::constTransport<Foam::speci es::thermo<Foam::hConstThermo<Foam:erfectGas<Foa m::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? #5 at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 at ??:? ^CAborted (core dumped) |
September 11, 2015, 03:03 |
anonymous
Rep Power: 12 |
Your courant number is blowing up. Reduce timestep and modify controlDict to allow the timestep to adapt to the courant number
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
