September 21, 2015, 21:53 |
patchMap
Rep Power: 13 |
Hi foamers,
I am wondering if I can use mapFields utility to map the vectorFields from one patch to another without mapping the internalFields? Mapping the internalField takes too long. I have searched throughout the forum that patchToPatchInterpolation should work, but it does not seem to work in parallel. Any suggestions? Thank you very much! |
September 22, 2015, 08:31 |
Ferdinand Pfender
Rep Power: 12 |
yes you can map patches to each other.
requirement is, that they have the same location as described here: http://cfd.direct/openfoam/user-guide/mapfields/ you can define patchmap in mapFieldsDict. I had some problems with the mapFields-utility in Version 2.3.x and 2.4.x -- since there is parallel support implemented, patchmapping did not work for me -- serial and parallel. So i switched to 2.2.x for the mapping process. Bugreport: http://cfd.direct/openfoam/user-guide/mapfields/ Greets, Ferdi |
September 22, 2015, 21:16 |
Rep Power: 13 |
Thank you very much for your help Pfender.
I have no problem using mapFields and have successfully integrated it into my code mapping data every timestep from one mesh to another. The problem is that it takes too long and I intend to do an implicit coupling using patchMap which is faster than mapping volume fields. I have looked into the partchToPatchInterpolation, but it does not work in parallel. Any suggestions? I appreciate your time. carlen |
September 23, 2015, 05:28 |
Rep Power: 18 |
This is also of interest to me, I want to map data from coarse patches to finer patches in my solver. It may be possible to use it in parallel if the case is decomposed in such a way that each patch is on one processor only.
September 23, 2015, 20:22 |
Rep Power: 13 |
Hi chriss,
Unfortunately OF does not have such capability as far as I know |
MeshToMesh parallel | ganeshv | OpenFOAM Programming & Development | 17 | December 21, 2023 13:58 |
runTime mapFields from fineMesh to coarseMesh | Carlen | OpenFOAM Programming & Development | 15 | November 14, 2022 21:39 |
How to Map Fields in openFOAM using the utility | Alhasan | OpenFOAM Running, Solving & CFD | 42 | January 15, 2018 08:52 |
