Permission denied issue for OpenFoam 2.3.1 on Ubuntu
I have successfully installed OpenFOAM on a virtual machine and in dual boot on a desktop. I have successfully compiled several of the tutorials and am able to visualize results in ParaView. So far so good. I am trying to run new cases developed as part of a workshop that I coordinated for CFD for Wastewater. These were developed and run in a Windows port of OpenFOAM. I have dropped the new cases into the VM running Ubuntu at home/randal/OpenFOAM/randal-2.3.1/run/cases. When I drop down into the sub directories and try to execute a run script I get a permission denied error:
home/randal/OpenFOAM/randal-2.3.1/run/tutorials/cases/s02_clarifier/Clarifier$ ./Allrun.pre bash: ./Allrun.pre: Permission denied I tried: sudo chown -R /home/randal/OpenFOAM/ and got this reply: chown: missing operand after ‘/home/randal/OpenFOAM/’ I then tried: sudo chown -R randal /home/randal/OpenFOAM/ and it seemed that the command had been executed, but when I went back to the new case and tried the run script I got another 'Permission denied'. Any help appreciated. Randal |
Quick answer:
chmod +x All* edit: :eek: My colleague Nelson was who delivered that session workshop and I was the one who helped prepare that case for him to present! :) edit 2: I've added this question to the FAQ: http://openfoamwiki.net/index.php/FA...application.3F |
Thanks Bruno. That seems to have worked within the directory containing the script. Add a -R to get permissions for a bunch of sub-directories?
Nelson did a great job in the workshop. Thanks so much for your great efforts to do up the examples. Cheers, Randal |
Hi Randal,
chmod +x */All* Code:
echo */All* Quote:
Best regards, Bruno |
Bruno,
May I indulge your Super Moderator status a bit more? the chmod command delivered from within the Clarifier directory allowed the Allrun script to run, but it aborted as follows: [0] [0] [0] --> FOAM FATAL ERROR: [0] driftFluxFoam: cannot open case directory "/home/randal/OpenFOAM/randal-2.3$ [0] [0] FOAM parallel run exiting [0] Another permissions error? Thanks again for your help. Randal |
Hi Randal,
That's a very odd error message!? Ah, OK, I've ran the case on my side on Linux and I've gotten the same issue, although a bit different: Code:
driftFluxFoam: cannot open case directory "/home/ofuser/clarifier/processor0" Please run the following commands within the "clarifier" folder: Code:
./Allclean And now you should be able to run Allrun with success... er, actually, driftFluxFoam won't run well yet. The case that was prepared for blueCFD-Core 2.3-1, which is based in OpenFOAM 2.3.x from March 18th, 2014. But since then, OpenFOAM 2.3.x continued to be updated and improved and OpenFOAM 2.3.1 was release on the 10th of December of 2014. In this version of OpenFOAM, driftFluxFoam was updated to work with all turbulence models, while the version in OpenFOAM 2.3.x from March is using an internal k-epsilon turbulence model. I'll send you a private message in a few minutes, so that I can send you the updated case via email. Best regards, Bruno |
