October 13, 2015, 02:09 |
Rocket nozzle simulation , simulation time
Hilbert
Rep Power: 10 |
Dear Foamers,
I have been working on rocket nozzle simulations, and after some effort got them to work. (once have a comparison with my current commercial code CFX i will post a reference here) I use coarse mesh to get a initial result, then map that solution to a fine mesh, on which i generate my final result. What I have noticed is that when I use mapFields to map my coarse mesh to my fine mesh I get oscillations/steps in the mapped solution. And certainly in the subsonic region of the rocket nozzle it takes a while to get rid of those using the compressible solvers. I was therefore wondering if anybody has an suggestion/experience with a smoother that i can use to smooth out my solution on the fine grid before i start iterating on my fine grid? |
October 13, 2015, 08:25 |
Vincent RIVOLA
Rep Power: 18 |
Which solver do you use for your nozzle simulations? Are they steady state or transient? In MapFields you have different methods to make the mapping: - cellVolumeWeight - direct - mapNearest Did you try all of them? Maybe one is better than the others for your case. |
October 15, 2015, 20:59 |
Hilbert
Rep Power: 10 |
thanks for your reply.
I know mapfields has different mapping options. The 2 non default ones did work. (there was an error in one, and the other had a non-physical result.) I am currently working with the transient solvers. Correct me if i am wrong here, but the steady state compressible solvers aren’t set up with hyperbolic equations and therefore cannot handle supersonic flow? (If you do know of a good steady state supersonic solver I am all ears). What I currently do is run the startup simulation with sonicFoam, and run the dense mesh with rhoCentralFoam |
October 16, 2015, 02:21 |
Vincent RIVOLA
Rep Power: 18 |
You may want to try the dbnsFoam (or dbnsTurbFoam) solvers available in foam-extend. They are supposed to do a better job for supersonic flows. |
How to export time series of variables for one point? | mary mor | OpenFOAM Post-Processing | 8 | July 19, 2017 10:54 |
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Need help with a rocket nozzle simulation | badboyz31 | CFX | 14 | September 22, 2014 00:06 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
