Compressible subsonic 2d airfoil investigation |
February 22, 2018, 10:59 |
Max
Hi Foamer-Community,
I'm trying to simulate an Airfoil 2D with OpenFoam and run into divergence problems. I started with 100 m/s (AoA=2°) and increased the velocity step by step to now 180 m/s. For 200 m/s the simulation crashes after reaching about 800 iterations. The residuals of k and epsilon increase and they are bounded. I use rhoPimpleFoam and the mesh should be fine. There are no warnings when running checkMesh. As turbulence model kEpsilon is activated. TimeStep is set to 1e-4. I'm running openFoam in a virtualbox. The domain consists of one disk with one cell thickness. The airfoil is cut out in the center of the disk. So there are 3 boundaries: Airfoil(wall); Farfield(inlet and outlet to produce 360° polars); Symmetry_Plane(front and back side of the disk) It would be great to get some advices. I tried a lot but nothing succeeded. Here are some specifications of my case: Code:
fvSolution: solvers { "(p)" { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.001; } "(p)Final" { $p; relTol 0; } "(rho|U|e)" { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0.001; } "(rho|U|e)Final" { $U; relTol 0; } "(k|nTilda|epsilon)" { solver GAMG; smoother DILUGaussSeidel; tolerance 1e-08; relTol 0.001; } "(k|nTilda|epsilon)Final" { $U; relTol 0; } } PIMPLE { momentumPredictor yes; transonic no; nOuterCorrectors 50; nCorrectors 1; nNonOrthogonalCorrectors 0; consistent yes; SIMPLErho yes; residualControl { "(U|k|epsilon)" { relTol 0; tolerance 0.0001; } } turbOnFinalIterOnly no; } relaxationFactors { fields { "p.*" 1; "rho.*" 1; } equations { "U.*" 0.9; "(e|h)" 0.7; "(k|epsilon|omega).*" 0.8; } } thermophysicalProperties: thermoType { type hePsiThermo; mixture pureMixture; transport sutherland; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleInternalEnergy; } mixture { specie { molWeight 28.97; } thermodynamics { Cp 1007; Hf 0; } transport { As 1.458e-06; Ts 110.4; } } boundaries: alphat: dimensions [1 -1 -1 0 0 0 0]; internalField uniform 1e-3; boundaryField { Airfoil { type compressible::alphatWallFunction; value $internalField; } Symmetry { type empty; } Farfield { type calculated; value $internalField; } } epsilon: dimensions [0 2 -3 0 0 0 0]; internalField uniform 200; boundaryField { Airfoil { type epsilonWallFunction; value uniform 200; } Symmetry { type empty; } Farfield { type inletOutlet; inletValue uniform 200; value uniform 200; } } k: dimensions [0 2 -2 0 0 0 0]; internalField uniform 1; boundaryField { Airfoil { type kqRWallFunction; value uniform 1; } Symmetry { type empty; } Farfield { type inletOutlet; inletValue uniform 1; value uniform 1; } } p: dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1.0e5; boundaryField { Airfoil { type zeroGradient; } Symmetry { type empty; } Farfield { type fixedValue; value $internalField; } } T: dimensions [0 0 0 1 0 0 0]; internalField uniform 288.15; boundaryField { Airfoil { type zeroGradient; } Symmetry { type empty; } Farfield { type inletOutlet; value $internalField; inletValue $internalField; } } U: dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform (99.94 3.49 0); boundaryField { Airfoil { type noSlip; } Symmetry_Plane { type empty; } Farfield { type freestream; freestreamValue uniform (99.939083 3.489950 0); } } Code:
[1] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [1] #1 Foam::sigFpe::sigHandler(int) at ??:? [1] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" [1] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ??:? [1] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ??:? [1] #5 ? at ??:? [1] #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [1] #7 ? at ??:? [openfoam-VirtualBox:16350] *** Process received signal *** [openfoam-VirtualBox:16350] Signal: Floating point exception (8) [openfoam-VirtualBox:16350] Signal code: (-6) [openfoam-VirtualBox:16350] Failing at address: 0x3e800003fde [openfoam-VirtualBox:16350] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fb0575734b0] [openfoam-VirtualBox:16350] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x38)[0x7fb057573428] [openfoam-VirtualBox:16350] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x354b0)[0x7fb0575734b0] [openfoam-VirtualBox:16350] [ 3] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE9calculateEv+0x184)[0x7fb05cd58de4] [openfoam-VirtualBox:16350] [ 4] /opt/openfoam5/platforms/linux64GccDPInt32Opt/lib/libfluidThermophysicalModels.so(_ZN4Foam11hePsiThermoINS_9psiThermoENS_11pureMixtureINS_19sutherlandTransportINS_7species6thermoINS_12hConstThermoINS_10perfectGasINS_6specieEEEEENS_22sensibleInternalEnergyEEEEEEEE7correctEv+0x2a)[0x7fb05cd6865a] [openfoam-VirtualBox:16350] [ 5] rhoPimpleFoam[0x42ab96] [openfoam-VirtualBox:16350] [ 6] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf0)[0x7fb05755e830] [openfoam-VirtualBox:16350] [ 7] rhoPimpleFoam[0x4328f9] [openfoam-VirtualBox:16350] *** End of error message *** |
airfoil 2d, compressible, rhopimplefoam, transient 2d |
Problem with airfoil shape optimization | robyTKD | SU2 Shape Design | 7 | March 7, 2022 16:18 |
SU2 AOA optimization | 454514566@qq.com | SU2 | 9 | March 7, 2022 16:17 |
Ffd_control_point_2d | feiyi | SU2 | 4 | September 30, 2019 12:42 |
High drag for airfoil compared to XFOIL and wind tunnel data | Ry10 | SU2 | 15 | October 30, 2016 17:27 |
2D FFD Optimization | RLangtry | SU2 | 2 | August 5, 2014 09:48 |
