beamEndLoad: Possible bug in Stress analysis
Old   October 15, 2015, 19:04
Default beamEndLoad: Possible bug in Stress analysis
Jerome Berryhill
Jerome Berryhill is on a distinguished road
I made a modification of the beamEndLoad case (bEL). The original code has a 30X1X1 beam, with one end fixed, and a shear traction applied in the Y direction applied to the opposite end. The beam is represented as a single block with (6,2,1) cell structure. I modified this, so that the last sixth of the beam is a separate block, and put a face on the -Y side of that block, with a traction in the +Y direction. That is, I replaced the shear on the end with a normal force from the bottom, in the same direction. I would expect the results to be nearly identical, but in fact they are very different.
Is this a bug? Or am I doing something wrong?
from blockMesh;
vertices
(0 0 0) // 0
(25 0 0) // 1
(25 1 0) // 2
(0 1 0) // 3
(0 0 1) // 4
(25 0 1) // 5
(25 1 1) // 6
(0 1 1) // 7
(30 0 0) // 8
(30 1 0) // 9
(30 0 1) // 10
(30 1 1) // 11
blocks
hex (0 1 2 3 4 5 6 7) (5 2 1) simpleGrading (1.0 1.0 1.0) // left part of beam
hex (1 8 9 2 5 10 11 6) (1 2 1) simpleGrading (1.0 1.0 1.0)
edges
boundary
pressureFace
type patch;
faces
(1 2 9 8)
fixedEnd
type patch;
faces
(0 4 7 3)
from 0/D
dimensions [ 0 1 0 0 0 0 0 ];
internalField uniform ( 0 0 0 );
boundaryField
pressureFace
type tractionDisplacement;
traction uniform (0 10000 0);
pressure uniform 0;
value uniform (0 0 0);
fixedEnd
type fixedValue;
defaultFaces
type empty;
Jerome Berryhill is offline   Reply With Quote
Old   October 15, 2015, 21:11
Jerome Berryhill
Ooops. Never mind. I had x1, x2, x3 confused with x, y, z.
OpenFOAM stress analysis results are showing 8-10% error with analytical solution. Sargam05 OpenFOAM 3 May 5, 2017 11:39
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
What does uniform temperature rise mean for thermal stress analysis? Sargam05 OpenFOAM 4 September 22, 2012 21:00
[stressAnalysis] Steady-state thermal stress analysis by using solidDisplacementFoam Sargam05 OpenFOAM CC Toolkits for Fluid-Structure Interaction 16 September 13, 2012 08:04
stress analysis -Von Mises Theory watashiwa OpenFOAM 7 October 15, 2010 15:43
