Velocity components residuals are missing when running with interDyMFoam
Like Tree7Likes
  • 4 Post By wyldckat
  • 1 Post By wyldckat
  • 1 Post By kmefun
  • 1 Post By YanaLolux
Old   October 16, 2015, 12:37
Smile Velocity components residuals are missing when running with interDyMFoam
vsammartano's Avatar
Vincenzo
vsammartano is on a distinguished road
Send a message via Skype™ to vsammartano
Hi there,
I'm quite new to OpenFOAM and I am working on a CFD simulation of a Cross-Flow water Turbine. I have created the OpenFOAM case and the simulation seems to work fine. BUT, during the simulation, in the terminal I can't read the residual of the velocity components. I know that the solver computes those unknowns, I want see these residuals during the simulation.
How can I do that!?
Thanks in advance!
PS: I am using the interDyMFoam solver
vsammartano is offline   Reply With Quote
Old   October 17, 2015, 05:37
Bazinga is on a distinguished road
how do you start the solver? I just tried a tutorial and the residuals and simulation information were shown in the terminal after I just typed the solver name.
Bazinga is offline   Reply With Quote
Old   October 17, 2015, 14:18
Retired Super Moderator
Bruno Santos
Quick answer: Check the file "system/fvSolution", search for the block "PIMPLE" and check if this line exists:
momentumPredictor no;
If you have it defined like this, then this means that the velocity (momentum) equation isn't solved directly.
Old   October 18, 2015, 05:55
Smile ...easy solution!! finally!
Vincenzo
Dear Bruno, I'm so grateful to you for helping me out! I was stucked! it was such an easy solution ... tomorrow I'll modify the fvSolution file as you told me! YEP!
thank you again!
Old   October 18, 2015, 06:05
Smile
Vincenzo
Dear Bazinga, thank you for your suggestion. Obviously I started the solver typing the name of the solver in the terminal. I think this is the only way to start a simulation in OpenFOAM.
In my case the problem was that in the fvSolution file, located in the system folder, the momentum equation was not solved directly...thus I caould not find the residuals of the velocity components.
Thank you again!
cheers!
Old   October 19, 2015, 07:37
Vincenzo
Dear Bruno, I modified the fvSolution file as you suggested....it works! Could you please suggest me some reference where I can read how does this solver work? Thank you again,
cheers!
Old   October 24, 2015, 13:20
Bruno Santos
Quick answer: Unfortunately I'm not familiar with any reference documentation for interDyMFoam.
Nonetheless, there is some about interFoam: https://openfoamwiki.net/index.php/InterFoam
The "DyM" part means "Dynamic Mesh" and is a mechanism that is mostly common to all solvers that have this tag in their name. Google:
OpenFOAM dynamic meshing explained
vsammartano likes this.
Old   September 10, 2016, 00:54
carno
Carno is on a distinguished road
I also have exact same problem. My velocity components are not getting printed on screen to monitor. Here is a log,
Create time
Create mesh for time = 0
SIMPLE: convergence criteria
    field p      tolerance 0.0001
    field U      tolerance 0.0001
    field "(k|omega|epsilon)"    tolerance 0.0001
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RAS
Selecting RAS turbulence model kOmegaSST
Selecting patchDistMethod meshWave
kOmegaSSTCoeffs
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.55555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
Creating MRF zone list from MRFProperties
    creating MRF zone: MRF1
Creating porosity model list from porosityProperties
Porosity region porosity1:
    selecting model: DarcyForchheimer
    creating porous zone: rad
Using pressure implicit porosity
No finite volume options present
Starting time loop
Time = 1
GAMG:  Solving for p, Initial residual = 1, Final residual = 0.0229096, No Iterations 1
time step continuity errors : sum local = 0.16611452, global = -0.013244094, cumulative = -0.013244094
smoothSolver:  Solving for omega, Initial residual = 0.0074746818, Final residual = 1.6552667e-005, No Iterations 1
smoothSolver:  Solving for k, Initial residual = 1, Final residual = 0.0020565579, No Iterations 1
ExecutionTime = 393.767 s  ClockTime = 394 s
Time = 2
GAMG:  Solving for p, Initial residual = 0.99980948, Final residual = 0.028042093, No Iterations 1
time step continuity errors : sum local = 1373.7404, global = -115.04725, cumulative = -115.06049
smoothSolver:  Solving for omega, Initial residual = 0.001862281, Final residual = 2.6651327e-006, No Iterations 1
smoothSolver:  Solving for k, Initial residual = 0.99999977, Final residual = 0.00054471924, No Iterations 1
bounding k, min: -30136.2 max: 40949627 average: 31.478273
ExecutionTime = 547.618 s  ClockTime = 548 s
The part of my fvSolution is as below,
SIMPLE
    residualControl
        p               1e-4;
        U               1e-4;
        "(k|omega|epsilon)" 1e-4;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
    nUCorrectors    2;
    momentumPredictor   yes;
Kindly help..I am using porousSimpleFoam solver
Carno is offline   Reply With Quote
Old   September 11, 2016, 10:31
Kaufman
kmefun is on a distinguished road
Create time
Reading field p
Reading field U
kOmegaSSTCoeffs
    alphaK1         0.85;
    alphaK2         1;
    alphaOmega1     0.5;
    alphaOmega2     0.856;
    gamma1          0.55555556;
    gamma2          0.44;
    beta1           0.075;
    beta2           0.0828;
    betaStar        0.09;
    a1              0.31;
    b1              1;
    c1              10;
    F3              false;
Starting time loop
Time = 1
Time = 2
SIMPLE
    residualControl
        p               1e-4;
        U               1e-4;
    pRefCell        0;
    pRefValue       0;
    nUCorrectors    2;
Hi
you can set nUCorrectors 0;
to use pressure explicit porosity and then it will go through the block that solving momentum equation. More details can be referred to the files createPorousZones.H and UEqn.H which located at applications/solvers/incompressible/simpleFoam/porousSimpleFoam/
Hope this could help you.
Carno likes this.
kmefun is offline   Reply With Quote
Old   September 12, 2016, 11:39
carno
Thanks ... It works
Old   February 6, 2022, 07:51
Default velocity components residuals
  #11
saeed sangchooly
saeed sangchooly is on a distinguished road
dear Bruno,
I'm working with multiphaseEulerFoam solver with 3 phases
I did set momentumPredictor to yes and I've also tried setting nUcorrectors to 0; but still I can't see the velocity component residuals. why is that?
how can I fix this?
saeed sangchooly is offline   Reply With Quote
Old   August 9, 2022, 09:04
Michele
YanaLolux is on a distinguished road
same problem here...
saeed sangchooly likes this.
YanaLolux is offline   Reply With Quote
Old   October 24, 2022, 10:49
Mario
MarioM is on a distinguished road
Originally Posted by saeed sangchooly View Post
dear Bruno,
how can I fix this?
I face the same problem. Could you solve it?
MarioM is offline   Reply With Quote
Old   October 24, 2022, 12:23
Post
  #14
saeed sangchooly
Apparently they've daisabled the momentum perdictor in this solver since it does no good in the sake of stability and acuracy in multiphase cases.
From what I've understood so far, Velocity whould be obtaind by solving momentum algebraically immedirely after solving poisson for p_rgh and updating rho (based on the equation of state specified for each phase) .
In that case, there whould be no velocity residuals which we can monitor
pls correct me if i'm wrong
openfoam, residuals, u components
velocity components at blade tip Sridevi CFX 3 April 30, 2022 11:55
Calculate velocity components from shear stress Arnoldinho OpenFOAM Running, Solving & CFD 0 August 29, 2011 12:07
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Variables Definition in CFX Solver 5.6 R P CFX 2 October 26, 2004 02:13
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
