Solution Control: is my equation need a symmetry, assymetric or diagonal solver? |
October 19, 2015, 11:56 |
Matt
Rep Power: 13 |
I am trying to use the correct solvers within fvSolution. However, I could use some help determining whether asymmetric, symmetric, or diagonal solvers should be used.
Here is the solver equation: Code:
fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) == flowDirection*gradP ); solve(UEqn == -fvc::grad(p)); Also, under what conditions would you already know the lower diagonal, upper diagonal, or both? From my basic education in CFD, I have only known solution matrices where the diagonals are the only known elements. |
October 20, 2015, 04:14 |
Nima Samkhaniani
Rep Power: 24 |
i guess it is asymmetric matrix, however use easy method !!! try and error.
you can assign asymmetric matrix for example PBICG if it does not work, change it
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
October 21, 2015, 21:04 |
Matt
Rep Power: 13 |
LOL! Yea, I read in the online documentation that it would let you know if it was wrong. I was hoping to get a little more insight into the matter though
Pressure distribution on a wall | darazsbence | CFX | 17 | October 6, 2015 10:38 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
Neumann Boundary Condition for Poisson Equation solution in Polar Coordinates | prapanj | Main CFD Forum | 2 | July 30, 2011 19:07 |
