Euler-Euler dispersed phase simulation
Old   October 21, 2015, 05:17
Default Euler-Euler dispersed phase simulation
Ali
ali.m.1 is on a distinguished road
Hi all
I'm trying to set up a simple case with a water/particle mixture. I've done this using DPMFoam, however I'm struggling to do it with an Euler-Euler solver. twoPhaseEulerFoam is ok, but I have trouble with the temperature equation as it diverges, and crashes the simulation: is there anyway to turn this off (without modifying the source code)?
twoLiquidMixingFoam is working too, but it only gives alpha.water, and has limited options for the dispersed phase.
Does anyone know of the best solver to use, so I can get stuck into one? I keep jumping around solvers right now...
Cheers
Ali
ali.m.1 is offline   Reply With Quote
Three Phase flow into a reservoir... akjha Main CFD Forum 0 December 15, 2014 07:01
Phase change simulation in a tube. AdarshGouda FLUENT 3 April 25, 2013 00:55
Two continuous phase and One dispersed phase Michael CFX 2 January 14, 2010 15:19
CFD simulation of Three phase separator tushar393 Main CFD Forum 3 December 22, 2009 22:41
phase change of a dispersed fluid Alex phillips CFX 1 October 23, 2006 14:40
